Author Topic: Nav / Anchor switch connections and problem  (Read 831 times)
May 13, 2014, 07:42:57 PM
Read 831 times
mvandale
« on: May 13, 2014, 07:42:57 PM »
I'm new to this forum so I hate to ask another nav light question but I have to..  I have a new old boat 96 225 Explorer. The NAV lights only come on when the switch is in the Anchor position.  The first time I tried this even the anchor light came on.  After trying a few things now the anchor light doesn't work but in the Anchor position the nav lights still come on, but not when NAV is selected.  I am not good at wiring so I'm not sure but I'm wondering if the wires are connected to the switch correctly.  If I can figure how to attach an image small enough I will..
May 13, 2014, 07:52:10 PM
mvandale
Re: Nav / Anchor switch connections and problem
« Reply #1 on: May 13, 2014, 07:52:10 PM »
This is the switch with wires connected.
May 13, 2014, 08:35:38 PM
« Reply #2 on: May 13, 2014, 08:35:38 PM »
The drawing on the left is way your switch is supposed to be wired...
Note the anchor light feed terminating to the upper right terminal on the switch, then jumping down to the lower right terminal.  This allows the anchor light to come on when the NAV lights are on (switch flipped up), but allows only the anchor light to come on when switch is flipped down.
The Nav light feed terminates to the lower left terminal, it most likely will have another feed piggybacked on it, that would be for your compass back light.  I believe '96 panels had a separate switch for gauge back lighting...
May 13, 2014, 08:37:20 PM
« Reply #3 on: May 13, 2014, 08:37:20 PM »
Forgot to mention, you have toggle switches, so there is no indicator light.  Ignore the ground reference...
May 13, 2014, 09:17:11 PM
« Reply #4 on: May 13, 2014, 09:17:11 PM »
Excellent diagram SB :salut:
mvandale, welcome aboard!
Seabob is a professional rigger with a TON of experience. He has built, rigged, and supervised Aquasport production for many years. We are fortunate to have his expertise here.
May 13, 2014, 09:25:24 PM
« Reply #5 on: May 13, 2014, 09:25:24 PM »
Scotty, as many NAV/ANC light switches as I've wired, you'd think I'd know my drawing by heart now...nope.  Every time I do another one, I still pull it out...
Thanks, Bud! :salut:  :salut:
May 14, 2014, 05:04:16 AM
futch13
« Reply #6 on: May 14, 2014, 05:04:16 AM »
Amen!!  I still draw it out every time I replace a switch also :roll:  :roll:  :lol:  :lol:  :lol:
May 14, 2014, 05:11:27 AM
« Reply #7 on: May 14, 2014, 05:11:27 AM »
Quote from: "mvandale"
MV, don't "attach" pics.  Upload them to your photo gallery here which will resize to the right size. Follow the directions here viewtopic.php?f=7&t=111
BTW, it almost sounds like your switch has been installed upside down.  "Nav comes on at anchor".
May 14, 2014, 07:39:05 AM
« Reply #8 on: May 14, 2014, 07:39:05 AM »
Well thanks, Loye, I don't feel like such a dumba$$ now...
The second method I drew, which is something you won't see on Aquasports, uses a SPDT switch and a diode, as opposed to the more common DPDT switch and no diode.  Nothing but a cost saving here for the builder.  DPDT switches are around $3 more than SPDT switches.  Throw in a 2 cent diode from China and the builder gets a tidy little $3 more on the bottom line per boat...
May 14, 2014, 08:39:32 AM
redemn93
« Reply #9 on: May 14, 2014, 08:39:32 AM »
do you have to use a nav/anchor switch or is there a way to make it work with 2 different switches without using a 3 wire anchor light?  im having trouble with that.  trying to use one switch for anchor and one for nav but my anchor switch feeds back to the nav light and turns it on too.  i know why.  i just cant figure out how to wire it differently.  i have a 2 wire anchor light now.
May 14, 2014, 08:44:00 AM
« Reply #10 on: May 14, 2014, 08:44:00 AM »
Jason, a 3 wire anchor light works 2 ways.  With 1 feed, it turns on half the light when running (along with the nav lights), when the anchor light switch is thrown, the whole light comes on, indicating anchored position.  Install a diode in the lead from the anchor light to the nav lgt switch.  You want the silver end of the diode to be oriented towards the anchor light switch. Current can flow from the nav lght switch, but it can't flow from the anchor lgt switch...
May 14, 2014, 09:18:02 AM
redemn93
« Reply #11 on: May 14, 2014, 09:18:02 AM »
what rating diode?
May 14, 2014, 10:12:36 AM
« Reply #12 on: May 14, 2014, 10:12:36 AM »
Something that would handle 12 volts and 1-2 amps should work fine.
May 14, 2014, 10:20:59 AM
redemn93
« Reply #13 on: May 14, 2014, 10:20:59 AM »
thanks.  might be doing this tonight.
May 14, 2014, 10:58:46 AM
« Reply #14 on: May 14, 2014, 10:58:46 AM »
Get one at Radio Shack.  The NAV/ANC circuit is typically protected by a 5A breaker, so like Bob said, but I'd try to get as close to 5A as possible.
