Author Topic: Ideas on Installing Baystar Hydraulic Steering  (Read 1505 times)
July 25, 2016, 09:07:25 PM
ShawnsIronman
Re: Ideas on Installing Baystar Hydraulic Steering
« Reply #15 on: July 25, 2016, 09:07:25 PM »
Hydraulic is awesome, but unless you are putting a jack plate on or bracket I would reconsider. I would not do the upgrade unless you feel your steering cable is getting tough to steer. If it ain't broke then don't fix it.
July 28, 2016, 12:43:13 PM
Dano
« Reply #16 on: July 28, 2016, 12:43:13 PM »
Is it worth spending the extra $$ for Seastar steering on a 115hp motor? I have a jackplate and the cable is ok but would rather have the Hydraulic but see a lot of discussions as to just saving and getting the seastar. At most later on the boat would get a 150hp.
July 28, 2016, 02:14:28 PM
BMAC1988
« Reply #17 on: July 28, 2016, 02:14:28 PM »
I have a baystar on my 140 with a jack plate and it works great, solid as a rock. save youre money for other upgrades and go with the baystar. just be careful because raising my motor up to lock the trim I ended up breaking off the fitting going into the cylinder.
Brett
95 OSPREY 175, Suzuki Df140,  CMC High Speed Jack-Plate, Baystar hydraulic steering, Standard Horizon VHF,  Digital Antenna, Dual GARMIN 541S, BENNETT Tabs, S&E Customs Leaning Post, Dual Batteries, T-Top,
July 28, 2016, 02:45:47 PM
« Reply #18 on: July 28, 2016, 02:45:47 PM »
 just received the "Vertical Tees" for my steering cylinder - I'll let you know how it works out.
