Author Topic: Rotten wood in gunwale (200 CCP)  (Read 1128 times)
April 30, 2014, 05:36:50 PM
Re: Rotten wood in gunwale (200 CCP)
« Reply #15 on: April 30, 2014, 05:36:50 PM »
Take the screws out  and the covering boards will come off.  Then just scrape the old wood off, and bond an new piece of marine plywood back on, put a layer of glass over it, drill holes for the rod holders/outriggers, seal the edges, and you are good to go!   :cheers:  Bed the covering boards in 5200 when you put them back on and it will reduce the squeaks when you sit or step on the covering boards...  :thumleft:
