Author Topic: New 22-2 Owner -Advice while rigging motor  (Read 424 times)
April 28, 2014, 09:31:34 AM
Read 424 times
BertD
« on: April 28, 2014, 09:31:34 AM »
Hello all,
Just picked up a 1976 Aquasport 22-2 (is this a flatback??) which I plan to build into an Ultra budget bay rat for fishing, clamming, tubing, and cruising. This will be a 2nd boat so I am trying to keep the cost as low as possible using all used parts etc..I picked up the boat for 600bux with a 1999 175HP Johnson on the back which has bad compression in 2 cylinders. I sold that motor for parts ($800.00) and now picked up a 1992 Suzuki DT 140 ($700.00) which has perfect compression in each cylinder. I am looking for advice on the gotcha's with this boat while I have the motor off and in the process of rigging the Suzuki on? Mounting height? Prop size and pitch? Transom plate? I wanted good gas mileage so I elected to go with the smaller 4 cylinder Suzuki.
Also, the floor is OK, only soft spot is the small access channel running down the side of the boat where the cabling and rigging run.
When I open the access hatch in the floor near the transom I don't see any foam in there, I do see a little water (under the floor), is this normal? The fuel tank is shot, I plan to just use an above deck 24 gallon tank under the console since there seems to be plenty of room under there.
For the money, she's not a bad boat, bow rail was removed- holes filled, transom is solid, no major cracks, Has 2 pedestal seats with cushions, stereo, VHF, depth finder. No trailer, I bought her in the water and drove her about 5mins down the canal to a friends dock with the bad motor (it does run, just not well), hoping when I pull her out the bottom doesn't have some major repair or something wrong :)
April 28, 2014, 09:53:36 AM
Re: New 22-2 Owner -Advice while rigging motor
« Reply #1 on: April 28, 2014, 09:53:36 AM »
Here's a start.
http://www.classicaquasport.com/gallery ... hp?cat=544
If it's a 76, it's not a flatback.
72 I believe is the cutoff date for that model hull.
viewtopic.php?p=38572#p38572
May 01, 2014, 12:17:22 PM
BertD
« Reply #2 on: May 01, 2014, 12:17:22 PM »
Great, thank you!
Starting to second guess myself here, the Suzuki I just picked up is a 20" shaft, this is what this boat requires, correct?
May 01, 2014, 02:26:37 PM
« Reply #3 on: May 01, 2014, 02:26:37 PM »
Just measure the middle of the transom from the top to the keel of the boat.  Should be about 20".
