Author Topic: 22-2 mullet boat  (Read 6897 times)
April 20, 2014, 01:11:06 PM
Read 6897 times
dirtwheelsfl
22-2 mullet boat
« on: April 20, 2014, 01:11:06 PM »
Helping a buddy build his new boat. Upgrading from a 19-6 actually. This one was almost all original except for some crab pot hauling mods. Doing the transom first, then stringers will be cut down to increase fish hold depth, theyre well attached so going to dig the foam out, tab the inside and recap them. Big decks and ice boxes front and rear...
Outside skin was not salvageable
Formica dam set up
New outside skin laid up. 4x1708
1 1/2" coosa epoxied in
Anybody have a clue what this black "pipe" is?     Its original, has nothing on the outside going thru the bottom and is filled with what seems like resin
April 20, 2014, 01:19:06 PM
Re: 22-2 mullet boat
« Reply #1 on: April 20, 2014, 01:19:06 PM »
Looks like it's the base for a shoot-thru ducer.
April 20, 2014, 03:00:46 PM
dirtwheelsfl
« Reply #2 on: April 20, 2014, 03:00:46 PM »
I think youre onto something.     The whole keel area was balsa cored and it was total mush. Probably from the install of this thing. Ive never seen one like this, guess it got sheared off somehow...
April 20, 2014, 04:24:15 PM
« Reply #3 on: April 20, 2014, 04:24:15 PM »
Dirt, if you guys are not gonna mess with the hull in that area, cut the fitting off, grind it flat, call it a day...
April 20, 2014, 04:31:41 PM
« Reply #4 on: April 20, 2014, 04:31:41 PM »
I think I know that 22-2.
April 21, 2014, 01:01:51 AM
Aquasport Commodore
« Reply #5 on: April 21, 2014, 01:01:51 AM »
Man Dirt you wern't kidding :shock:  It does look like mine :mrgreen:  I need to put 2 more layers on the inside but had to stop. This weather was going downhill and thought it would rain. And Im using the 2 to 1 so it is ssssllllooooowww and time was not my friend. Oh well, just makes me want to put more one. Your's is looking good.
April 21, 2014, 09:55:31 AM
dirtwheelsfl
« Reply #6 on: April 21, 2014, 09:55:31 AM »
My thoughts too. Not gonna try and get it all out. Its not rusting so its gonna get glassed over..
Quote from: "wingtime"
Came from a crabber in Fort Myers i believe. He was selling it as a complete rig apparently, but he parted it out and my friend was able to get just the hull...
April 21, 2014, 10:02:14 AM
Callyb
  • MidWest
« Reply #7 on: April 21, 2014, 10:02:14 AM »
You do great, clean work. I guess that is where the Master part comes from! :salut:
Carl
___________________________
April 21, 2014, 12:18:47 PM
« Reply #8 on: April 21, 2014, 12:18:47 PM »
Quote from: "Callyb"
I got a feeling with the rebuilds that are going on right now, there will be several others joining Dirt's fraternity. :idea:
May 14, 2014, 07:41:00 PM
dirtwheelsfl
« Reply #9 on: May 14, 2014, 07:41:00 PM »
Moving right along as it appears my tutoring is working 8) ...    Inner transom skin laid up and stringers being cut down.  Took off 4.5" in the bow and 5" toward the stern.
Stringer extensions built on a dam just like the transom. Also tabbed the insides with 1708
The mush of balsa in the keel was replaced with a half section of 3" pvc, which is also the drain for the compartments to be built in the bow
Poured foam today, should have the stringers capped by the weekend
May 14, 2014, 09:16:30 PM
« Reply #10 on: May 14, 2014, 09:16:30 PM »
Nice... :salut:
May 14, 2014, 09:51:04 PM
Aquasport Commodore
« Reply #11 on: May 14, 2014, 09:51:04 PM »
Very clean and nice. Did you do a heavy grind on the hull or a light scuff?
May 14, 2014, 10:23:17 PM
dirtwheelsfl
« Reply #12 on: May 14, 2014, 10:23:17 PM »
Quote from: "86Aqua"
Everywhere were glassing to gets it pretty heavy. Flat enough to where theres no depressions left within the roving strands.  The owner got bored one day and went over the whole thing lightly though...
May 14, 2014, 10:26:31 PM
« Reply #13 on: May 14, 2014, 10:26:31 PM »
Quote from: "dirtwheelsfl"
And went home itching and told his wife, "Honey, I'm a boat builder!"   :roll:  :roll:
May 14, 2014, 10:43:20 PM
« Reply #14 on: May 14, 2014, 10:43:20 PM »
Dirt, beautiful work as always. Interesting, lowering the stringers for fish hold capacity. Especially when the recreational user raises them for self-bailing ability.
So...you bury the boxes...then from the forward fish box back, the console area, etc.  into the rear cockpit...that deck area is raised to self bail...is that the thinking?
