Can't really give much advise on the transom seeing that I haven't done one yet, sounds like he has done it this way before, so I would want to see pics and talk to other owners who he has done this for and check their perspective of his work after a year or two..The hull id # you can probably do what I had to do...had a engraving shop make me a plate out of stainless with the HIN on it and thru bolted it to the transom..it has passed Coast Guard inspection every year since(3)..Plan on adding a jack plate to mine sometime this year as well..who's are you going to use? Been looking at Boob's marine and a few others, non hydraulic..
The bolts in the bilge and the raw fiberglass are no problem at all. I would also recommend you have him add a hatch there in the back so you can tighten said bolts and install a bilge pump.
Quote from: "Blue Agave"The bolts in the bilge and the raw fiberglass are no problem at all. I would also recommend you have him add a hatch there in the back so you can tighten said bolts and install a bilge pump.X2. Nando's hatch allows plenty of room to access stuff...
