Author Topic: poly foam for stringers  (Read 826 times)
April 15, 2014, 07:37:59 PM
Read 826 times
elite51203
« on: April 15, 2014, 07:37:59 PM »
Ive searched online but I cant seem to really find what im looking for.  I'm looking for 2 inch thick 3-4lb foam poly sheets that i can use for stringer core material.  (4x8 sheets).  Locally in the central Florida or Tampa area.
Thanks!
Jay
rebuilding a 1978 20\' Proline
April 15, 2014, 07:52:43 PM
Re: poly foam for stringers
« Reply #1 on: April 15, 2014, 07:52:43 PM »
Try a dock supply house? :scratch:
April 15, 2014, 07:58:47 PM
« Reply #2 on: April 15, 2014, 07:58:47 PM »
this what you lookin for? http://www.fgci.com/
Mod Edit:
This will get you to the site. Looks like a lot of good stuff.
April 15, 2014, 08:04:34 PM
« Reply #3 on: April 15, 2014, 08:04:34 PM »
Aaron, linky no worky...
April 15, 2014, 08:09:00 PM
« Reply #4 on: April 15, 2014, 08:09:00 PM »
link works fine on my 'puter, they dont have a pic of the 2" 4lb foam... http://www.fgci.com/bp_productlist.aspx ... 27&level=4
April 15, 2014, 08:15:52 PM
elite51203
« Reply #5 on: April 15, 2014, 08:15:52 PM »
Yikes $400 a sheet? No thanks.
What about this?
http://www.fgci.com/bp_viewproduct.aspx ... tem=124988
Jay
April 15, 2014, 08:31:07 PM
« Reply #6 on: April 15, 2014, 08:31:07 PM »
Here ya go....and may can find it local
http://www.dockbuilders.com/dow-styrofoam-billets.htm
April 16, 2014, 06:15:39 PM
« Reply #7 on: April 16, 2014, 06:15:39 PM »
Jay, i personally wouldnt put anything less than 4 lb for the stringers
April 23, 2014, 06:28:42 PM
elite51203
« Reply #8 on: April 23, 2014, 06:28:42 PM »
I'm still searching uggh :scratch:
Jay
April 23, 2014, 06:34:46 PM
Callyb
  • MidWest
« Reply #9 on: April 23, 2014, 06:34:46 PM »
I don't understand exactly what you are going to do... :scratch: Can you elaborate a little bit? Polypropylene/Polystyrene would not be advisable for stringer material in my opinion. The bond (with the resin) you will get to with those products is not going to be strong enough to rely on the foam as a structural element. However if you are just going for a lost mold, that would be a different story.
Carl
___________________________
April 23, 2014, 06:42:17 PM
elite51203
« Reply #10 on: April 23, 2014, 06:42:17 PM »
My plan was to use the same type of stringer material and design that LilRichard used, seen below.  I like the idea of not having wood in the stringers.
Jay
April 23, 2014, 06:47:22 PM
« Reply #11 on: April 23, 2014, 06:47:22 PM »
I think he mentioned where he got that stuff in his thread - FGI maybe?
April 23, 2014, 07:36:20 PM
Callyb
  • MidWest
« Reply #12 on: April 23, 2014, 07:36:20 PM »
Ahhh, I gotcha now. I just went back and checked, Rick is correct he got it from FGCI.
That is Divinycell foam. It is made to be a coring material, totally different stuff than what I thought you were looking for.
See here: https://www.fgci.com/bp_subcats.aspx?catId=1323&level=3&cat=DIVINYCELL
That stuff just isn't that cheap, sorry.
Carl
April 23, 2014, 11:50:26 PM
« Reply #13 on: April 23, 2014, 11:50:26 PM »
Same here, was confused from the start. Thought you were looking  block foam to fill an existing stringer cavity. Then fill the rest with spray.
Since she's stripped....the current plan is a good one. As Carl says, good ain't cheap. The stringers are the foundation of your rebuild.
