And Yes new paint on the Aquasport 222 (Prob Oct, Nov 2013) and a new Transom (June and July 2013). You could say we might have worked a bit in reverse.
Thank you Capt Bob/ I just got done talking to 86Aqua on the foam about some things. He said you were a good guy!! He must came up to your area to see you for things. Ive seen all you discuss on here and I had the feeling you have done this a few times :-) (Of course meaning over a few). I appreciate you posting and helping me when you have.
Backwards or forwards....you still get BOB!
And let's not forget their most stunning similarity.Backwards or forwards....you still get BOB!
I have a visit next week with a fellow "high ranking" :!: , well respected CAS member. I've decided not to do anything really necessary until seeing his boat. I will not be able to recreate his Super Aquasport 222, but it will give me ideas. I'm very much excited about seeing it and I'll be jealous Joke of course, I'm ecstatic to see it.
And everything I plan, like not removing the casting deck as it is in good shape, has me concerned now, as I can not get all the foam out unless I remove it, at least not as I can see. But I have had recommendations not to not over stress it, as I've gotten as much foam out as my hand can reach up in there, and honestly although it makes me feel I'm side stepping a crucial step, The foam does seem dry up there. Again, right now 'm only doing what I feel I should. Removing the casting deck seems so unnecessary that I'm starting to feel that this is correct, and most of the wet foam was below it. I want to remove it, but I've been advised by an pro (so to speak) to leave it alone.
Working nights and then working on this has been tuff , I find myself just staring so much.
I've found things that confuse me, like why the drainage from the gunnel side of the stringers at the transom doesn't drain well. I know how to fix it, but part of me said yes run a drill through it and epoxy in a drain, then add a small bilge pumps to both sides as well.
