Gallery
Gallery
Plumbing
245 osprey live well/ wash down valve
Topic: 245 osprey live well/ wash down valve (Read 1834 times)
April 11, 2014, 02:16:37 PM
Rigging Master
Re: 245 osprey live well/ wash down valve
Reply #15 on:
April 11, 2014, 02:16:37 PM »
Agreed entirely!!
April 15, 2014, 01:01:32 PM
Bergertime
Reply #16 on:
April 15, 2014, 01:01:32 PM »
Bob- this is the right valve correct.. Item 31231?
B
98 245 Osprey / Johnson 225
April 15, 2014, 01:12:45 PM
Rigging Master
Reply #17 on:
April 15, 2014, 01:12:45 PM »
Bruce, yep, you can use that one. Your original is item 9153, we used the 3/4" barbs threaded into the legs of the valve...
April 18, 2014, 12:01:20 PM
Bergertime
Reply #18 on:
April 18, 2014, 12:01:20 PM »
Well after some experimentation with a couple different orders (both were wrong) the one I need is linked below. Unfortunately the pictures and descriptions on several websites are lacking. Anyway, I know what I need now for my Osprey (pic above) and it's not an emergency on my part.. just some upgrading. Hope this helps!
http://www.westmarine.com/plastic-plumb ... --14395941
B
April 18, 2014, 12:31:06 PM
Rigging Master
Reply #19 on:
April 18, 2014, 12:31:06 PM »
Bruce, that valve says 1/2" ID hose...you need 3/4"...
April 19, 2014, 12:06:57 PM
Bergertime
Reply #20 on:
April 19, 2014, 12:06:57 PM »
Hi Bob.. I ordered Item# 9155 (3rd Order) from GoodBoatGear.com (pic above). #9153 is the base mount version and #9155 is the flush mount version of the same valve. My plan was to un-thread my existing hoses and thread them into the new valve. Would this not work with the #9155? I know I need the flush mount version but when I look at the two I ordered in error they were no different except one came with threaded hose barbs and the other did not.
This is way to complicated.. lol However, I appreciate your help making sense of these as the descriptions are cryptic.
B
April 19, 2014, 01:22:14 PM
Rigging Master
Reply #21 on:
April 19, 2014, 01:22:14 PM »
Bruce, I do believe you ordered the correct valve, 1/2" threads will accept the barbs from your old valve.
How I installed those valves back then was to take them apart so that the circular face plate under the handle mounted flush, with the valve assy t/bolted behind it. When you take your old one off, you'll see how it's done...
April 28, 2014, 05:57:58 PM
Bergertime
Reply #22 on:
April 28, 2014, 05:57:58 PM »
Swapped out my valve this weekend. Easy peasey except for removing the old handle. That booger was a real pain to get off. Besides that, plug and play. Water tested her on Sunday and no leaks! Nice not to have to break a sweat turning that valve now! Thanks for your help Bob. The flush mount with threads was the ticket!
B
April 28, 2014, 06:19:07 PM
Rigging Master
Reply #23 on:
April 28, 2014, 06:19:07 PM »
Plumbing
