Did you fab that tank yourself? Nice job.
You might want to do some research on painting and sealing that tank before you cover it up for a few years. Search on this site you will find some good info.
QuoteDid you fab that tank yourself? Nice job. Yes. I have a small aluminum fabrication business building T-tops, casting platforms, etc. so the boat will is probably going to end up covered in aluminum accessories QuoteYou might want to do some research on painting and sealing that tank before you cover it up for a few years. Search on this site you will find some good info. It may be a little too late for that That being said, I've read a lot of info (from other sites mostly) on the paint, no paint, foam, no foam, do nothing, etc. and seems that there are many ways to skin the cat with no fail proof way of installing the tank. I do believe a properly painted tank will last longer, but there's a couple reasons I used the "do nothing" method. First being I'm a much better fabricator than painter and my fear would be that if I did not paint it properly then it would only add to the corrosion problem if the paint failed, chipped, or whatever. Second being is I can't say I've ever seen a tank with proper ventilation and grounding to fail unless something out of the ordinary happened, example being I've seen on two different occasions/boats the holding straps come loose from the rubber isolators and chaff a hole through in one and set up corrosion in the other. Time will tell but believe it will be there for years to come.
If you haven't finished the install yet and can still remove the tank you can coat it some of this. It will seal against moisture and will wick into crevices to help stop corrosion at those points. It is soluble in gas but as long as nothing leaks you should be good for quite a few years. Prep is minimal, just wipe aluminum with acetone or the wax and grease remover of your choice. When I pull my pie holes over my tank it is good to see the condensation beaded up on top of this product. It is used in automotive to seal inside the pillars around the doors. It will work very well inside of tubing of any kind. The material is kind of like a beeswax in a can but better!http://dominionsureseal.com/index.php?o ... -corrosion
Bradley what city are you in?
Bradley, you have some excellent metal fab and welding skills, you think about building t-tops, hardtops, and radar arches?
Here's the place to do a little "self promotion"...viewforum.php?f=12
wish you were closer. Id be placing an order for a fuel tank. thats next winter's task though.
