Author Topic: New (used) motor for Slipaway  (Read 2800 times)
April 02, 2014, 09:49:34 PM
Reply #75
Re: New (used) motor for Slipaway
« Reply #75 on: April 02, 2014, 09:49:34 PM »
More progress!
After thinking about the indentations overnight (and already having some bondo glass) I took Bob's advice and ground the gel out of the dents. I then wiped them with acetone and placed the bolts in from the outside of the transom till they were level with the bottom of the hole. I then mixed some up and spread it across, filling the low spots.
The best thing about bondo glass is just as starts to gel you can either shave it with a knife or start sanding with 80 grit. When it is this state of cure you can really cut some material without a lot of effort. The gelling starts in around 3-4 minutes after mixing.
April 02, 2014, 09:58:36 PM
Reply #76
« Reply #76 on: April 02, 2014, 09:58:36 PM »
After wiping all the holes and sanding them with 80 grit I drilled from outside with a 1/2 inch bit through the filler using the hole as a guide.
I then sanded them with 180 and tomorrow I will re gel on top after it cures some more.
The bottom port side one has almost 1/2 inch of filler to get it flush.
I also ordered the TH Marine plates today and will pick them up tomorrow.
And now for Bryan's request. The old binnacle, no sealant of any kind, twenty years of saltwater, still works but how I don't know.
April 02, 2014, 10:24:04 PM
Reply #77
« Reply #77 on: April 02, 2014, 10:24:04 PM »
Well done Lewis!!  And a great chat today.  I might add, after I got the Sea Sprite cleaned up today (grinding is an effin ball... :roll:  :roll: ), got to thinking about the Raymarine E80 i have...and the Raystar 120 GPS antenna I have...and could they be wired together...
I HAVE A FIX!!!  WOO HOO!!!  So the little boat will basically have a, as new, $2K Chartplotter!!  She must feel special!   :cheers:  :cheers:  :cheers:
April 02, 2014, 10:28:05 PM
Reply #78
« Reply #78 on: April 02, 2014, 10:28:05 PM »
At least you will know where you are from now on!!!   :cheers:  :cheers:  :cheers:  :cheers:  :cheers:
With the right transducer you can read bottom in 1500 ft!!
This I would love to see in that boat!!!  LOL!!!!!!!
April 02, 2014, 10:39:28 PM
Reply #79
icemanbryan
« Reply #79 on: April 02, 2014, 10:39:28 PM »
Well, if you ever get lost, you can go to the first Island you see and ask directions.
(Capt. Ron)
April 02, 2014, 10:44:29 PM
Reply #80
icemanbryan
« Reply #80 on: April 02, 2014, 10:44:29 PM »
Quote from: "slvrlng"
That binnacle looks like something we found diving at Catalina!
April 02, 2014, 11:02:21 PM
Reply #81
« Reply #81 on: April 02, 2014, 11:02:21 PM »
I have the ducer...but no DSM 300.  If anybody has a stand alone FF out there that they'd like to part with for a very reasonable price, I'm all ears...
April 02, 2014, 11:34:01 PM
Reply #82
« Reply #82 on: April 02, 2014, 11:34:01 PM »
Here ya go Lewis, not in the console yet, just on the bench...
Even has a Navionics card for SE FL and the Bahamas.  The Sea Sprite may see a little Gulf Stream action!!!
This is an E80, so it can do radar too...and I have a Furuno dome...hmmmmmmm......
April 03, 2014, 06:14:55 PM
Reply #83
« Reply #83 on: April 03, 2014, 06:14:55 PM »
Will this work Lewis?
April 03, 2014, 09:16:10 PM
Reply #84
icemanbryan
« Reply #84 on: April 03, 2014, 09:16:10 PM »
Alright Bob!
Making it happen.
April 03, 2014, 09:23:06 PM
Reply #85
« Reply #85 on: April 03, 2014, 09:23:06 PM »
A little nightime...
I realize it's overkill Bryan, but it works... :wink:
April 03, 2014, 10:59:09 PM
Reply #86
« Reply #86 on: April 03, 2014, 10:59:09 PM »
Overkill? Really?
LOLOLOLOLOLOL!!!!!!!!
That is actually a really nice looking setup!
Went to pick up the transom plates at my friends place and look what he had in the back of the shop.
April 03, 2014, 11:07:38 PM
Reply #87
« Reply #87 on: April 03, 2014, 11:07:38 PM »
Got back to the boat and finished out the indents then gelcoated them. They were just kicking pretty good when I left. Looks a lot better and is relatively fair. Bob, you can see part of the wiring I talked to you about.
I have one more pic for you tonight. I mostly worked on the gel tonight, wiring questions start tomorrow!
April 03, 2014, 11:24:28 PM
Reply #88
« Reply #88 on: April 03, 2014, 11:24:28 PM »
The round plug is TNT...
April 03, 2014, 11:27:33 PM
Reply #89
« Reply #89 on: April 03, 2014, 11:27:33 PM »
Are you sure??????
Just kidding!!!
