Aquasport Discussion
my boat pics
Topic: my boat pics (Read 404 times)
March 15, 2014, 08:44:36 AM
Read 404 times
truckie
my boat pics
March 15, 2014, 08:44:36 AM »
I cannot for the life of me upload pics to a thread (size) so I put them in a gallery I believe the link below will bring you there.
question one is about bottom paint...
question two is the damage under hull looks like its caused by roller on trailer
I need advice on both please
March 15, 2014, 08:56:13 AM
Re: my boat pics
March 15, 2014, 08:56:13 AM »
Truckie,
First upload your pics into your gallery on the site here and then post links from your gallery into your posts. It's real easy and here is a link that will walk you through it. Should take you 5 minutes to figure it out.
viewtopic.php?f=1&t=8843
March 15, 2014, 11:35:31 AM
truckie
Re: my boat pics
March 15, 2014, 11:35:31 AM »
http://www.classicaquasport.com/gallery ... at&cat=500
March 15, 2014, 11:36:51 AM
truckie
Re: my boat pics
March 15, 2014, 11:36:51 AM »
March 15, 2014, 11:37:40 AM
truckie
Re: my boat pics
March 15, 2014, 11:37:40 AM »
http://www.classicaquasport.com/gallery ... AG3254.jpg
March 15, 2014, 11:38:24 AM
truckie
Re: my boat pics
March 15, 2014, 11:38:24 AM »
ok above is a link to my pics....
so with the damage spot im going to use west system to repair
what kind , brand of bottom paint should I look for?
March 16, 2014, 08:24:20 AM
Re: my boat pics
March 16, 2014, 08:24:20 AM »
Looks like it is worn down all the way into the glass. To fix it right you will need to lam some glass layers across the area and then fair. is the bottom paint ablative? If it is, that is the type you need to spot in.
March 16, 2014, 11:02:03 AM
truckie
Re: my boat pics
March 16, 2014, 11:02:03 AM »
Yea its def. Worn down to glass. .. I m planning on sanding down that area and using west system and layer in glass etc.
It doesn't seem to be All the way through ,,and I don't think it has seen water this way ,so I want to fix it and sand entire bottom and paint before dropping in water for the season.
March 16, 2014, 11:13:50 AM
Re: my boat pics
March 16, 2014, 11:13:50 AM »
I'd use epoxy to repair that area since epoxy will prevent any water intrusion into the laminate.
March 16, 2014, 11:15:50 AM
truckie
Re: my boat pics
Reply #9 on:
March 16, 2014, 11:15:50 AM »
can I adjust the roller so it doesn't sit in that area anymore???
March 16, 2014, 02:09:11 PM
dburr
Re: my boat pics
Reply #10 on:
March 16, 2014, 02:09:11 PM »
Quote from: "truckie"
Short answer is yes to an extent..
To be more helpful it would be good to see a picture of the roller setup at a distance enough to see which way the roller truck needs to go and how far it can move before other problems are encountered. A bunk conversion might be appropriate but that is a bit more work then moving the roller trucks..
Standing by..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 16, 2014, 03:14:28 PM
truckie
Re: my boat pics
Reply #11 on:
March 16, 2014, 03:14:28 PM »
@ dburr thanks. Understood ..
Just read on the bottom if your info you have the same boat yr and all
Any info tips etc. That you have come across and wanna share with me that would be great
my boat pics
