Thanks guys. Deep down I knew that was the answer, but I was hoping someone would convince me that the smaller unit would work. I guess I really need to examine my garage/shop and see what I can do to fit a bigger unit in there. I've seen some 60 gallon compressors rated at ~12 cfm@90 psi that should do the trick. Thanks again
Craig, given that its most likely a one-time event.....could you rent what you need for a week or two?
Quote from: "CLM65"Thanks guys. Deep down I knew that was the answer, but I was hoping someone would convince me that the smaller unit would work. I guess I really need to examine my garage/shop and see what I can do to fit a bigger unit in there. I've seen some 60 gallon compressors rated at ~12 cfm@90 psi that should do the trick. Thanks again Keep an eye on craigslist. I got an 80gal compressor, all of the wire out of the fella's garage, 50' of air line, the motor starter, the wiring from that, and even help loading it for $200. Was a woman who's ex-husband had died, and had never bothered changing his will. Based on the prices she had on most of the stuff in his garage, she was not heartbroken that he was gone...Keeps up with everything I've thrown at it. Worst problem I've had is trying to use it when its bitter cold sometimes ice will form on the pressure switch and it won't cut off (but you're in Florida, so the weather won't be a problem...the drivers on the other hand, seem to be some of the worst in the world, so good luck with that :pirat: )
A friend of mine had the same problem. He asked me what he could do. This is what I told him. Get a 5hp compressor with a 20gal tank. Then get a few independent 10 gal tanks he bought 4 from harbor freight. We put them in the rafters of his garage. Then hooked them in series. This gave him more then enough air storage and the tanks were light enough to put in his rafters and out of the way. I’ve found, that getting a 5hp or more if you have the room is always best. when it come to cfm output and being able to run any air tool. Also with the smaller tanks you can mount them on a shelve high on the wall. They don’t have to be on the floor. Just my opinion.
Craig, unless you're a glutton for punishment, you'll want to spread that air-filing out over some time. It's not something I'd want to do day in, day out for 2 weeks...
