Author Topic: Continuous water in fuel  (Read 2180 times)
July 04, 2014, 05:46:11 PM
Reply #45
Dano
Re: Continuous water in fuel
« Reply #45 on: July 04, 2014, 05:46:11 PM »
one clamp only and not very tight at all. Now the hole where the old filler was is too big for the new one. Going to try and find a small piece of starboard to raise it up and cover hole. I will then install new filler thru that piece over the hole. ALso going to try and siphon out the water tomorrow thru the sending unit.
July 04, 2014, 05:58:26 PM
Reply #46
« Reply #46 on: July 04, 2014, 05:58:26 PM »
I knew it had to be something simple.  Glad you found the problem!
July 07, 2014, 07:17:58 AM
Reply #47
Dano
« Reply #47 on: July 07, 2014, 07:17:58 AM »
Its not the prettiest, but this will be better than what was there.
Tried to keep from cutting yet another hole in this boat.....
September 01, 2014, 07:59:06 PM
Reply #48
Dano
« Reply #48 on: September 01, 2014, 07:59:06 PM »
So far so good - no water in tank anymore. Interesting thing I found when checking the pickup for any obstructions. The 90 degree fitting had a small chunk of aluminum blocking the pickup tube. The shutoff block had no real cel supply coming thru it??  Cleared that with a pick and reinstalled the fittings. The boat finally ran great for miles at wot until the last time I tried to get up on plane. It would only reach 4000rpms. Thinking I've got an air leak somewhere or possible vst or injector issue now. Getting close to the finish line though!
