I guess I didn't specify enough...its still sort of rough/wavy (might have gotten a little crazy with the 60grit flap disc...it was 28deg and I was cold). Can I smooth it with some filler of some sort and then paint it? What would the "proper" course of action be in this case? I was going to fill the various holes with Marine Tex or Six10 (whichever I can find in the garage first) and then I wasn't sure what the best way to get it smooth would be.Seriously though, my buddy's first response was "find some better looking carpet".
SB, re the lead, good to know, was interested in the where and how. Mine is a-ok.Thanks, good info
Quote from: "gran398"SB, re the lead, good to know, was interested in the where and how. Mine is a-ok.Thanks, good info A little "sidenote" on lead usage Scotty (ya know I always have these little "rest of the story" bits... ). Around '08, the price of lead basically about quadrupled in price, maybe more. So JW tasked me and my engineering cohort to come up with a replacement. Our biggest constraint was the physical area where the ballast had to be located. Obviously, because of that, there was no substitute, in certain boats, lead had to be used. But where area size was not a factor? Bags of cement. Good ole Portland cement, stacked on top of each other, foamed and glassed in place. It was dirt cheap and obviously did the trick.Me thinks that would be a little difficult on an existing build, though...
If I skimmed it with a body filler, would Formula 27 work? My buddy has a wholesale account with a marine supplier and on our last order I thought I was ordering the cheapest flare kit I'd ever seen (so I ordered 3 of them). Turns out the catalog had a misprint, and the flares were supposed to be part # "XXX-OR"...instead they were shown as "XXX" with no suffix. That was also the part number (and price shown) for Formula 27, so I ended up with 3 cans of that instead of 3 flare kits. Rather than return it, for what little money it cost, I put it on the shelf. Seemed like I could use it somewhere. Maybe here?
One idea to validate the presence of water would be to cut an access hole for a pie plate or hatch in the area of the floor for mounting a bilge pump and drill and exporatory hole in the lower rear quadrant of the stringer, about 5" in front of the transom and up about 2" from the bottom and see if water starts to weep out of the foam.
