if you have to pull your floor you will be amazed at how wet the foam will be..
Better looking carpet...
Ryan, if you don't want to gelcoat it, get some Rustoleum topside paint at Loews. Looks and works good...
Quote from: "gman 82 aquasport" if you have to pull your floor you will be amazed at how wet the foam will be..Don't say that Garry... Ryan, seeming as the consensus opinion here is on the water logged foam, you can add ballast to port to offset the weight imbalance. Seeing as you are in construction, you most likely have access to a metals supplier, lead is an excellent material to use for ballast (we used it at Proline). Lots of weight in a small package...
That's almost verbatim what my buddy suggested. Bunch of wise guys darn it... plus I'd be crazy not to go hardwood if I'm sticking with flooring products
