Author Topic: Tow Vehicles: K&N Intakes  (Read 2418 times)
February 16, 2014, 10:27:17 AM
Reply #45
Re: Tow Vehicles: K&N Intakes
« Reply #45 on: February 16, 2014, 10:27:17 AM »
Quote from: "Circle Hooked"
Gentlemen these de rails are not to be tolerated in said forum, it's for informational purposes on trailers and tow vehicles ONLY, not sports, move it along please.
LOL!!!!!!
February 16, 2014, 11:47:55 AM
Reply #46
« Reply #46 on: February 16, 2014, 11:47:55 AM »
:thumleft:  :thumleft:
Scott, that was funny bro :flower: Guess you CAN derail your own thread :lol:
SB, that link to the Seafoam cleansing process is great. Given the detailed instructions, that is something that even I could do.
Thanks! :salut:  :salut:
February 16, 2014, 11:51:59 AM
Reply #47
« Reply #47 on: February 16, 2014, 11:51:59 AM »
Seafoam has it's detractors, Scotty...I suppose like just about anything.  But many people have used it from tiny little weed whacker motors up to big old V-8s...and have been happy with the results.
Like I said earlier, if this stuff didn't work, trust me it wouldn't be selling.  BTW, I even have a bottle of Marvel Mystery Oil in the shop.  If that doesn't sound like something a snake oil salesman would try to pitch, I don't know what does!! :thumright:
February 16, 2014, 11:57:25 AM
Reply #48
« Reply #48 on: February 16, 2014, 11:57:25 AM »
I used to use that Marvel on my old K 5 Blazer. Knocked the knock right outta it :mrgreen:
February 16, 2014, 02:58:49 PM
Reply #49
« Reply #49 on: February 16, 2014, 02:58:49 PM »
I had a K5, '78, 350.  Excellent truck, but traded it on (Scott and Aaron will love this) an F-150...
February 16, 2014, 06:02:04 PM
Reply #50
icemanbryan
« Reply #50 on: February 16, 2014, 06:02:04 PM »
I use that Marvel Mystery Oil all the time, it works great.
February 16, 2014, 06:52:54 PM
Reply #51
« Reply #51 on: February 16, 2014, 06:52:54 PM »
im running a stock airbox/filter on my f250 6.0L... most of the guys on the powerstroke forums agree that the stock airbox and filter for the 6.0L has more than enough flow to support up to 450-500 hp, they say at that point is when you'd need to switch to a better intake... so i will continue to run the stock filter as my turbo stays nice and clean and i dont plan on pushing the truck much past 400 hp once i get the head studs and head gaskets done... im also happy with my mileage, ive been getting 12-13 mpg city with a lead foot, and 19-21 mpg highway at 70-75 mph...
February 16, 2014, 07:01:16 PM
Reply #52
icemanbryan
« Reply #52 on: February 16, 2014, 07:01:16 PM »
Quote from: "Aswaff400"
Aaron, I have the 7.3 turbo.
I use the Ford AIS system, seems to work really well.
The Ford air boxes work well.
I have quite a few Banks upgrades, mine runs great.
Almost at 100K.
February 16, 2014, 07:28:40 PM
Reply #53
« Reply #53 on: February 16, 2014, 07:28:40 PM »
ive got 143,300 on my 6.0, it was a one owner from Arkansas and as far as i and my mechanic could tell, original head gaskets, and injectors. i do know the turbo was replaced. when i took it to my mechanic for a new oil cooler, egr delete, and a few other odds and ends, he said the motor was spotless inside and out... ive been thinking about getting the diesel site "wicked wheel 2" for my 6.0. they say it has a noticeable gain on the low end and mid range power, less lag, more boost, less drive preasure, lower egt's... and its only 230 bucks, cant hurt to try it... otherwise ive been thinking about getting the sinister diesel hot and cold side intercooler pipes and intake elbow just for a little bit of bling...
ww2
http://www.dieselsite.com/dieselsitewic ... rbo-2.aspx
sinister pipes
http://www.mkmcustoms.com/sinisterdiese ... dium=email
elbow
http://www.mkmcustoms.com/sinisterdiese ... elbow.aspx
February 16, 2014, 10:28:49 PM
Reply #54
« Reply #54 on: February 16, 2014, 10:28:49 PM »
Made the move up Bob!
BTW 176K on my 7.3 Powerstroke.
February 17, 2014, 11:32:29 AM
Reply #55
icemanbryan
« Reply #55 on: February 17, 2014, 11:32:29 AM »
ww2
sinister pipes
elbow
Aaron, just a suggestion.
Go online and find Diesel O Rings in Colorado.
Bob is the owner and has forgotten more than most guys know.
His truly is the guru of diesels and sells some items.
The blade you are speaking of is not a performance blade, just makes more noise.
He has others and really is the go to guy.
Check him out, he is the real deal.
EDIT, I might be incorrect, he may just do the 7.3's
B
February 18, 2014, 07:04:03 AM
Reply #56
« Reply #56 on: February 18, 2014, 07:04:03 AM »
i know the wicked wheel for the 7.3 doesnt make much of a difference, but on the smaller displacement 6.0 guys are posting on powerstroke.org, it made a noticeable difference. dieselsite installed one on a 6.0 with a stock turbo and stage one injectors( im guessing 155cc?) http://www.powerstroke.org/forum/6-0l-p ... rbo-4.html
February 18, 2014, 11:07:30 AM
Reply #57
icemanbryan
« Reply #57 on: February 18, 2014, 11:07:30 AM »
i know the wicked wheel for the 7.3 doesnt make much of a difference, but on the smaller displacement 6.0 guys are posting on powerstroke.org, it made a noticeable difference. dieselsite installed one on a 6.0 with a stock turbo and stage one injectors( im guessing 155cc?)http://www.powerstroke.org/forum/6-0l-performance-parts-discussion/364370-wicked-wheel-oem-6-0-turbo-4.html
Aaron, I really hope that is the case.
For a turbine to work better, it needs more air flow.
The air box and the air intake are a factor.
The exhaust back flow comes in play as well as the waste gate.
I spent quite a bit of time figuring out what to do when I did my truck.
The OP for the upgrade might have had some other mods as well.
Again, I hope it works for you.
February 18, 2014, 12:16:32 PM
Reply #58
« Reply #58 on: February 18, 2014, 12:16:32 PM »
Marc, Scotty has a Tahoe with the 5.3 I believe.  There are some engines that simply don't benefit from a cold air intake, my Maxima is one of them.  I'e done the research, the HP gains are minimal and occur at such high revs that I would never see them.  Interesting that the oil from the filter guimmed up your IAC and TPS.  For those that may not know, that's Idle Air Control valve and Throttle Position Sensor...both residing in the throttle body.
I did some quick research on the use of the K&N on Scotty's Tahoe, their site stated an 11 HP gain at something like 5300 RPM...somehow I don't think Scotty's going to be seeing those kind of revs anytime soon!
Exactly what my mechanic stated, air flow increases on a chart jump up only at the higher REVS, thats why I pulled it out.. not needed in my opinion..
February 18, 2014, 12:39:38 PM
Reply #59
« Reply #59 on: February 18, 2014, 12:39:38 PM »
Hmmmm  I may have to consider a Wicked Wheel 2 for my 7.3.
