Engines & engine woes
Manual lift for outboard
Topic: Manual lift for outboard (Read 1202 times)
July 05, 2006, 08:26:23 AM
Read 1202 times
Dave D
July 05, 2006, 08:26:23 AM »
The tilt motor on my 1998 Johnson outboard stopped working. I was able to lower the motor using the manual relese but now I can not lift the engine to trailer it to the repair shop. Does anyone know if it is possible to lift the engine by hand?
Thanks,
Dave
July 05, 2006, 08:43:00 AM
steved
July 05, 2006, 08:43:00 AM »
I don't know if it is the same for Johnsons but with my Mariner, you need to put the engine in gear to be able to tilt it up manually. Once it's up, you can shift back to neutral.
22.2 CCP (1982)
July 05, 2006, 09:28:01 AM
Dave D
July 05, 2006, 09:28:01 AM »
Thanks for taking the time to reply, I will give it a try.
Dave
July 05, 2006, 02:12:33 PM
DEFIANT
Guest
July 05, 2006, 02:12:33 PM »
It has been quite a few years since I had a Johnson but I think there is a screw on the tilt cylinder that needs to be turned. Once it is backed out a few turns you can raise the motor by hand.
Good Luck!
