Author Topic: Hi all! 1st post: Ye Ole Gastank Filler Hose Problems  (Read 1979 times)
February 10, 2014, 04:52:20 PM
Re: Hi all! 1st post: Ye Ole Gastank Filler Hose Problems
« Reply #15 on: February 10, 2014, 04:52:20 PM »
NC,
I moved your thread to the Rebuild in hopes that it will also help you and another member doing the same fuel hose replacement on similar models.
February 10, 2014, 04:57:09 PM
Bergertime
« Reply #16 on: February 10, 2014, 04:57:09 PM »
Excellent outcome!  You know what BOAT really stands for beyond "Bring Out Another Thousand??"
"Nothing is ever easy!"
B
98 245 Osprey / Johnson 225
February 10, 2014, 09:20:56 PM
dirtwheelsfl
« Reply #17 on: February 10, 2014, 09:20:56 PM »
Quote from: "Bergertime"
B
I thought it was Bend Over And Take it ?     :D
February 10, 2014, 10:34:18 PM
gman 82 aquasport
« Reply #18 on: February 10, 2014, 10:34:18 PM »
Both would be accurate :roll:
glad you got the hose loose, hopefully it will slide out without problems..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 12, 2014, 04:48:38 PM
Aquasport Commodore
« Reply #19 on: February 12, 2014, 04:48:38 PM »
Quote from: "dirtwheelsfl"
B
 :shock:  :mrgreen:
February 24, 2014, 10:03:11 PM
NC Aquasport
« Reply #20 on: February 24, 2014, 10:03:11 PM »
Well...I was able to twist the old hose loose. Before pulling it through, I ran a line through the new hose, then through the old hose into the coffin. At the top end of the new hose, I tied off the rope with a metal bar. Also connected the two hoses together using metal wire and duct tape. Lubed up both hoses as well as the inside of the hull wall with tons of that white lithium spray grease. Slowly pulled the old hose out into the coffin with the new hose following behind it while keeping tension on the rope to prevent the hoses from separating from each other. Got it through for the most part. Pulled through pretty easy with the lithium grease.
February 24, 2014, 10:10:29 PM
« Reply #21 on: February 24, 2014, 10:10:29 PM »
Thats good news!  Another good lube to use is plain old dish washing soap since it will dry with time.
March 20, 2014, 09:26:48 AM
NC Aquasport
« Reply #22 on: March 20, 2014, 09:26:48 AM »
Success
Had to cut the hole bigger so I could get my hand in to pull the hose through. What a pain in the arse!
Now I'm using some PVC strips to put under the gas tank to keep it off the bottom and let some air circulate.
March 20, 2014, 10:11:11 AM
gman 82 aquasport
« Reply #23 on: March 20, 2014, 10:11:11 AM »
Great job with the fuel lines :salut:
What did you coat your with?
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 20, 2014, 10:26:05 AM
« Reply #24 on: March 20, 2014, 10:26:05 AM »
Sweet!!
Once everything is hooked up, chocked down, etc., consider spraying a little foam around the hoses where they pass through the glass as a chafe guard :thumright:
March 20, 2014, 10:12:33 PM
gman 82 aquasport
« Reply #25 on: March 20, 2014, 10:12:33 PM »
What did you coat your tank with?
Sounds better that way doesn't it :scratch:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 24, 2014, 09:17:17 AM
NC Aquasport
« Reply #26 on: March 24, 2014, 09:17:17 AM »
Quote from: "gman 82 aquasport"
Hey Master,
Sorry for the delay. I coated the tank in Zinc Chromate (Moeller Brand - https://www.google.com/#q=yellow+zinc+c ... 4733140320).
Picked up a rattle can of it at the local hardware store. Apparently its excellent at preventing/slowing down corrosion on aluminum tanks...especially in salty conditions. Just make sure you spray in an open area away from anyone and wear good breathing protection.
March 24, 2014, 09:35:09 AM
« Reply #27 on: March 24, 2014, 09:35:09 AM »
It used to be, in aerospace, EVERYTHING was primed with zinc chromate before painting...
