Author Topic: Some advice, floors, materials...  (Read 1420 times)
January 29, 2014, 11:33:57 AM
Re: Some advice, floors, materials...
« Reply #15 on: January 29, 2014, 11:33:57 AM »
Quote from: "Capt Matt"
Five stringers wide 22 flat back?
Looks like she was redone once before
Capt Matt
Mine had 5 stringers as well.  It is original, but not all of them had 5 stringers apparently.
January 29, 2014, 01:33:22 PM
« Reply #16 on: January 29, 2014, 01:33:22 PM »
Quote from: "CLM65"
Capt Matt
mine also had 5 stringers, all you need is 2. the middle one is just a waist of space.
January 29, 2014, 01:47:06 PM
« Reply #17 on: January 29, 2014, 01:47:06 PM »
Agreed on the keel "stringer", Aaron.  A heavy laminate (3/4"+ solid glass) takes care of the keel strength...
January 29, 2014, 01:50:35 PM
BowMovements
« Reply #18 on: January 29, 2014, 01:50:35 PM »
So that brings me to another question.  Without putting a frame up to hold the boat straight, am I ok cutting out a section of the center stringer to make room for a custom fuel tank without foaming and capping the stringers I emptied out first?
January 29, 2014, 04:08:42 PM
« Reply #19 on: January 29, 2014, 04:08:42 PM »
before you add any glass or foam, it would be a good idea to block the boat and get it nice and square/level. also get her nice and low to make the millions of climbs in and out that much easier.
I raised the height of my stringers about 4-1/2 inches which gave me plenty of room for a 62 gallon tank I got of the web. you dont need a custom tank to fit, just need to get a plan, measurements, and search for a deal on a tank at a fraction what a custom tank may be.. when I first started on the boat, I thought about leaving part of the middle stringer but quickly decided to cut it completely out to gain a ton of space below deck
March 27, 2014, 11:53:59 AM
BowMovements
« Reply #20 on: March 27, 2014, 11:53:59 AM »
Still alive after what seems to have been weeks of sanding and fairing and new foam and recapping old stringers.  I'm tired.  I have a question for you gents.  I need to mix up some build-up material to gloop onto the stringer tops like was originally there.  Whats the best mix for the price?
March 27, 2014, 12:30:05 PM
« Reply #21 on: March 27, 2014, 12:30:05 PM »
Are you trying to raise the stringers...or glue the deck back in?
March 27, 2014, 01:28:40 PM
BowMovements
« Reply #22 on: March 27, 2014, 01:28:40 PM »
A bit of both.  I am going to go with 1/2 marine ply glassed on both sides.
