Engines & engine woes
DAMAGED OMC FLYWHEEL
Topic: DAMAGED OMC FLYWHEEL (Read 759 times)
December 22, 2013, 12:11:24 PM
Read 759 times
floridamisser52
December 22, 2013, 12:11:24 PM »
Did something stupid. ( This is usually how I preface my posts
) At my Dad's request was trying to make his OMC Johnson 89 25hp a pull start in addition to electric . Bought a parts motor that I think is good to make the conversion. Took a traditional puller and put it way out to the perimeter , tightened down to much, and popped a piece of the edge off . After said screw up jb welded it back . Can I move forward with this , crank it , test it . Figured I'd ask the smart guys. Thanks guys, and Merrry Christmas
December 22, 2013, 12:44:40 PM
Re: DAMAGED OMC FLYWHEEL
December 22, 2013, 12:44:40 PM »
I'm not one of the smart guys, but I'll take a shot anyway. JB Weld is some good stuff, but your talking about a piece of metal rotating at several thousand RPM. That piece will become a missile if it comes loose. IMO, the risk of injury is just not worth it.
December 22, 2013, 03:25:43 PM
Mechanical Master
December 22, 2013, 03:25:43 PM »
Well said Craig and very true. The flywheel may also be bent now and/or micro cracked; dangerous @5000 rpm. The proper place to attach the puller is through the 3, 1/4 or 5/16 threaded holes at the center of the flywheel hub. Use a harmonic balancer puller, not a jaw type puller; most auto parts stores will rent one. So I'm assuming it broke a piece of the ring gear off? If so, eventually the starter pinion gear will break the JB weld repair anyway. Replace the flywheel.
December 22, 2013, 09:01:24 PM
Mechanical Master
December 22, 2013, 09:01:24 PM »
Ditto to the above. Never remove a flywheel with an jaw-type puller from the OD of the flywheel.
December 22, 2013, 09:14:36 PM
Rigging Master
December 22, 2013, 09:14:36 PM »
FYI, I just replaced the harmonic balancer on the Jeep, 5.2L Chrysler. Rented the puller from AZ, worked like a champ...
December 23, 2013, 12:32:07 AM
icemanbryan
Guest
December 23, 2013, 12:32:07 AM »
Yes, replacement it please!
Not worth keeping it for the damage it could do.
