AH the memories LOL attach a life line to yourself when you try to pull start that thing in the water
Misser, will do. Have to pick up some fuel hose, probably some fittings as a few fuel lines on the PH going to the fuel pumps are preformed, braided with crimped on ends, and they are rotted as well. Nothing I didn't expect. Can probably get by with barbed fittings and hose, unless I wanted to make her "authentic". No high pressure chit to worry about. She'll definitely need a set of plug wires and plugs, new timing belt, then to figure out (I'm sure Farley knows the drill) how to set timing.But you all will get a vid, promise! You guys know I like to make videos!! Scary, actually...
I have the pre '65 factory service manual for it. So we can walk through the set up when the time comes. Whatever you do, don't break the distributor cap! They are gold and crazy expensive. Also looks like she has been opened up for surgery at least once. Looks like old sealer on the crankcase joint (not factory). If this engine was in my shop right now; before I put a penny into it; I would be doing a compression test and be looking for 110-120 psi and go from there. You will be able to find just about every part you need to get it run. Once you get on the site, you will find a bunch of guys that have access to parts for it. But for now, just she if she has a heartbeat in the cylinders.
Lewis, I saw on ebay last night just looking around, the front "plate" for a 700, perfect condition...$269 I think they wanted! I don't think so...
