When putting my boat away for the winter I noticed that the new-last-season Loadstar/Kenda 205 75D-14 tires are showing excessive 'cupping' wear on the inside edge of each. Since they both show the same inside wear, I'm thinking whatever is causing it is happening to both sides at once and that it might be a weak axle, bending down under the weight of the boat and forcing the tires outward and putting more load on the inside edges of the tread? It's a 1999 single-axle Continental aluminum holding a 1999 200 Osprey. It was a FLA/saltwater rig before I found it here in OH-IO, and there is some surface rust showing on the rectangular beam that holds the axle. Any thoughts/advice?
Is there a round axle inside the rectangular tube with the surface rust -- and is that axle what may have 'advanced' rust? Just curious about how that is constructed.
At each end of the square axle tube is a stub axle (sometimes called a axle spindle)
Quote from: "wingtime"At each end of the square axle tube is a stub axle (sometimes called a axle spindle)I knew it started with an "S".
