Author Topic: what's on your boat "to do" list  (Read 951 times)
November 16, 2013, 10:53:20 AM
FJStretch
Re: what's on your boat "to do" list
« Reply #15 on: November 16, 2013, 10:53:20 AM »
Here is some of my list:
Rewire and organize wiring under console (it's a mess).
Replace steering arm (rust!).
Patch some voids under rub rail.
Patch some holes in console that were created for misc electronics by the previous owner.
Install new VHF antenna
Address weight distribution/scuppers under waterline issue ( :scratch:
Considering paint job. Hull above and below waterline looks pretty bad and original decals are pealing/cracking.
I rebuild prefer to do all this above myself. I can handle the electrical and mechanical, but the paint job issues would be a learning experience for me. I could end up with a bigger job if my stringer foam is waterlogged... And I have basically no experience with fiberglass or foam work. I never pulled a deck or cap before.  :shock:  I love too learn new things but don't want to bight off more than I can chew.
FJ Stretch (Member #3324)
1986 Aquasport Osprey 200
November 16, 2013, 01:57:46 PM
gman 82 aquasport
« Reply #16 on: November 16, 2013, 01:57:46 PM »
It's a never ending list!!! :pirat:
#1..repaint floor with nonskid(adhesion problems with original paint 2 years ago)
#2..Raise motor 1 bolt hole higher :salut:
#3..Make a enclosure for T-Top as soon as I find an industrial sewing machine thats priced reasonable. :thumright:
#4..If I get a wild hair up my(well you know), sand and repaint the bottom of the boat white..
And just maybe look for a 222CCP hull, depending on how all else goes. :lol:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
November 16, 2013, 04:53:57 PM
bondobill
  • West Coast
« Reply #17 on: November 16, 2013, 04:53:57 PM »
Quote from: "Capt. Bob"
Trim/tilt motor.
I've already purchased a new one, just haven't installed yet.
Will be pulling the motor off and inspecting the transom.
Probably won't complete till the first of next year.
Bob
Does your's look like this
It is off a 89 Yami 225 Exell
If its the same and you could use it you are welcome to it.
This motor has been lying around for a few years in my shop....time to throw it out
Bill
1979 222 FF
- Winston Churchill
Bill
November 16, 2013, 10:52:32 PM
« Reply #18 on: November 16, 2013, 10:52:32 PM »
That is my exact unit. :thumright:
Please shoot me a PM with your thoughts and let's see if we can make medicine.
Thanks!
November 18, 2013, 08:43:38 AM
jdupree
« Reply #19 on: November 18, 2013, 08:43:38 AM »
Quote from: "gman 82 aquasport"
Gary, let's go get that 222 CCP down at Harkers Island :thumright:
John L. Dupree, III
AQABLA84E999
Member #257
November 18, 2013, 09:50:39 AM
Rhojo
« Reply #20 on: November 18, 2013, 09:50:39 AM »
My list started with lower unit service this off-season. It's time for new impellars and gear oil. Now that I have gotten into my motor issue on the starboard motor that is quickly going to move to the top of my list.
So my list is:
repair/replace starboard powerhead  :study:
LU service both motors  :puker:
Spread some teak oil around  :thumleft:
clean/clean/clean,wax/polish/buff  8)
Jon & Rhonda
'79 22-2 Family Fisherman  "Lillypad"
November 20, 2013, 08:52:59 PM
Capt Matt
« Reply #21 on: November 20, 2013, 08:52:59 PM »
Need to repaint inside of boat and top of cap
500 plus trips on her are starting to show, just cosmetic though not a stress crack to be seen
Need new cushions made
Custom made grey powder coated aluminum switch panel with high end switches
Winter is my busy time so probably won't get done for a while
Capt Matt
Light tackle sportfishing
November 21, 2013, 09:42:48 AM
gman 82 aquasport
« Reply #22 on: November 21, 2013, 09:42:48 AM »
JD, pm sent...Thanks
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
November 21, 2013, 11:59:01 AM
Bluecrab72
Cooler weather means time for repairs.
« Reply #23 on: November 21, 2013, 11:59:01 AM »
The first things I want to tackle are getting some new paint on and a new rub rail.
November 22, 2013, 11:14:37 AM
jdupree
« Reply #24 on: November 22, 2013, 11:14:37 AM »
PM sent.
John L. Dupree, III
AQABLA84E999
Member #257
November 22, 2013, 03:39:44 PM
fishboy316
  • Mid Atlantic
« Reply #25 on: November 22, 2013, 03:39:44 PM »
Mine will be in service most of the winter. Want to mak a few trips to Va Beach Va. Go out of Rudy inlet to fish stripers. Fish the chesapeake till 12/15 then the CBBT till the 12/31. then Rudy thru mar.
#1 new steering cable.
#2 check transom and stringers to see how wet.
#3 repair gunnel on port side.(old repair that needs replacing.)
#4 paint topside.
Sure there is more but don"t know what.
Bill
