Author Topic: proper grounding on a gas tank  (Read 724 times)
November 06, 2013, 10:00:34 PM
Read 724 times
love2fish
« on: November 06, 2013, 10:00:34 PM »
I was reading a thread on Jamestown Distributers website about improper grounding and i wanted to make sure i grounded my gas tank correctly.
Originally (and still) I had just a ground from the tank's ground tab directly to my negative terminal on my #1 battery.
now that I'm switching to an electric fuel sending unit, I have the tank still grounded as well as the sending unit grounded (unit is grounded to my NEG bus bar). When i get my fuel gauge it will be grounded and I'll connect the POS leads....
I also grounded the fuel fill when i replaced that a few weeks ago... all that sound correct?
Chris
\'74 22-2
Member #921
November 06, 2013, 10:13:32 PM
Re: proper grounding on a gas tank
« Reply #1 on: November 06, 2013, 10:13:32 PM »
For me it is Chris.
Just the way I have mine.
November 06, 2013, 10:21:45 PM
« Reply #2 on: November 06, 2013, 10:21:45 PM »
Yep.  The key is to have a lead from the tank to the ground bus, the fill to a ground bus, the sender ground to a ground bus (or, in the sender's case, if you want, all the way to the ground post on the gauge).  If you have continuity to ground throughout, all are happy...
November 10, 2013, 08:18:07 AM
« Reply #3 on: November 10, 2013, 08:18:07 AM »
What is the proper size for the wire connecting the fill and tank to the ground bar?  I think I read 8 ga, but I want to be sure...
November 10, 2013, 09:17:19 AM
« Reply #4 on: November 10, 2013, 09:17:19 AM »
Craig, per ABYC H-24, Sect. 24-15, Fuel system grounding...https://law.resource.org/pub/us/cfr/ibr ... 4.1993.pdf
Note there is no call-out for wire size, simply a requirement for resistance...
However, in ABYC E-01, Bonding in DC systems, it does state that the bonding wire shall be no less than 8GA...https://law.resource.org/pub/us/cfr/ibr ... 1.1973.pdf
Do I agree with them?  No.  And there must be a means of interpreting the section in E-01 that allows builders to use a smaller gauge, as there are no small boats (<26') out there that I know of that use 8GA, yet still meet ABYC req.s...
November 10, 2013, 11:00:17 AM
« Reply #5 on: November 10, 2013, 11:00:17 AM »
Thanks Bob.  8 ga does seem kinda large.
November 10, 2013, 11:29:28 AM
« Reply #6 on: November 10, 2013, 11:29:28 AM »
Craig, where I see 8GA is on twin inboards, where you have rudder ports, shaft struts, stuffing boxes, intake strainers, all that wonderful stuff that has to be bonded.  When they go that route, you'll usually see all the t/hulls and shut-off valves bonded as well...
November 10, 2013, 06:39:52 PM
« Reply #7 on: November 10, 2013, 06:39:52 PM »
Quote from: "CLM65"
I guess we go back to the poly tank "thing" again - do we need to ground the fill or the tank  :scratch:
November 10, 2013, 07:03:36 PM
« Reply #8 on: November 10, 2013, 07:03:36 PM »
So what would be a good guage for the application?
They have a habit of corroding and rotting under the deck.
November 10, 2013, 07:12:37 PM
« Reply #9 on: November 10, 2013, 07:12:37 PM »
Are you talking about poly tanks?   :scratch:
November 10, 2013, 07:41:10 PM
« Reply #10 on: November 10, 2013, 07:41:10 PM »
No, ground wires on tanks in general. They go green at the connection and look like a petri dish over time.
November 10, 2013, 08:20:41 PM
« Reply #11 on: November 10, 2013, 08:20:41 PM »
I have a 10 gauge on my tank and fill.
Same size was used on my CCP.
It was fine when I pulled the tank (CCP) 14 years later.
November 10, 2013, 08:23:45 PM
« Reply #12 on: November 10, 2013, 08:23:45 PM »
Quote from: "RickK"
Quote from: "CLM65"
I use a 10 AWG.
Poly or not, you still need to bond the fill, unless it is poly also.
November 10, 2013, 08:25:29 PM
« Reply #13 on: November 10, 2013, 08:25:29 PM »
First, in response to Rick's question.  On a poly tank install, no bonding is necessary, not even the fill.  Any physical contact with the tank (through the fill hose) is with a non-conductor...plastic.  Thus, no static electricity can accumulate.
What I would suggest on the tank sender (I think this is your big gripe here, Scotty...) is quality adhesive lined heat shrink terminals, a proper application of either dielectric grease or anti-corrosion spray, and stick with the gauge wire that does the trick...16GA.  Yes, you can step up to 14GA, but with a proper install, and proper maintainance, the 14 won't offer any less resistance than the 16.
The problem with tank senders and the wiring turning into something that looks like a spore colony in a petri dish is that nobody pays any attention to them!!  How many people pull their inspection pies and look at their wiring on a yearly basis?  How about every 6 months?  I'd say about 5% of the boater population.  And how many people, when they see a bit of water accumulating on top of their tank, stop their boating activities until they can track down the source and eliminate it?  I'd say about .05%!
The point I'm trying to make is that there is no CORRECT wire size for bonding.  Yes, in theory, if the bonding system is part of a lightning protection system, and thus is terminated to a Dynaplate in contact with the water, then I would want 8GA.  But trust me, with the copious amounts of voltage a direct hit can produce, even 4/0 cable will be toast!!  The key is proper install and maintainance.  That keeps the resistance to a minimum, and keeps nasty little critters from colonizing on top of your sender...
November 10, 2013, 08:31:27 PM
« Reply #14 on: November 10, 2013, 08:31:27 PM »
Bob, you are correct, E-01 does state that any metallic components of the fuel system must be grounded.  However, as an "out", typically, on new boats, which is what I am used to, boats which have poly tanks typically have plastic fills.
