Bruce, the upper portion of the actuator has a coil in it, with a rod protruding down through the center of the coil into the lower portion. As the rod moves up and down with the action of the actuator, the change in strength of the magnetic field of the coil is what is measured, and translated into a display...at least that's what I draw from the construction. The rod has "cut" marks so the trimdicator kit can be used with all existing Bennett actuators, you just shorten the rod to fit your actuator..
Yepper. The top of the actuator threads onto the actuator body. Unscrew the old, screw on the new one (have to enlarge the hole where the hose passes through to route the lead into the boat), and wire it up. With your HDS-7, you can have the tabs displayed on your head unit...http://www.bennetttrimtabs.com/indicators.php?cID=2
BTW, do you have the old style or the new?
Well my good Aquasport friends. I chequed the engines and they are mounted on the second hole. But, did notice the bothe engines are mounted 3/4 of an inch towards port from center line. My 270 lists port. Could this be the problem and if it is could it be fixed?
