Author Topic: Trailer tongue failur/replacement  (Read 1748 times)
November 04, 2013, 04:53:09 PM
Read 1748 times
Georgie
« on: November 04, 2013, 04:53:09 PM »
So, I was wondering the other day why I was having such a hard time getting my trailer jack rotated under my trailer and getting the lock pin to engage; I had to lift up MUCH harder than usual to get enough clearance between the trailer and the ground  :scratch: ....  until I stood amidships and looked at the tongue.   :shock:   She'd rusted so badly from the inside out that I hadn't noticed, the bottom wall of the 3X4" galvanized tube was completely severed, and a crack had formed in both side walls that ran to within an inch of the top of the tube!  Appears I was lucky she didn't completely fold and result in a complete nose-dive on the way home from the ramp.   :oops:
Now for the hard part...I have an OLD shoreline galvanized tilt-tongue trailer (the body and axle are in perfect shape otherwise I'd just replace the whole thing, and Shoreline has been out of biz forever) so I'd need a 9 ft. long replacement piece of 3" X 4" galvanized tube to start my repair.  Any ideas for sources?  I've tried most of the basic on-line sites (approx $200-ish) and my local trailer shop says he's only got one piece of 3X4 left so they can't sell it.
Also, anybody have any knowledge of welding galvanized steel?  From what i've read it puts off some pretty noxious fumes but if you're working in a well ventilated area with a big box fan to blow the fumes away, then it can be done with the same equipment as normal steel welding b/c the melting point of the zinc is SO much lower than that of the steel.   :?:
Thanks in advance for any insight, gents!   :salut:
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
November 04, 2013, 05:33:06 PM
Re: Trailer tongue failur/replacement
« Reply #1 on: November 04, 2013, 05:33:06 PM »
Ryan, rather than replace the whole length of square tubing, why not just cut off the fwd bad section, get a "sleeve" that 3"X4" slides into, and go with the shorter (and much easier to get!) piece to replace the rusted out part?  No welding, all bolts.  Unless you feel the whole piece isn't too far behind the bad section...
November 04, 2013, 06:34:43 PM
« Reply #2 on: November 04, 2013, 06:34:43 PM »
i have welded galvanized steel a few times, it welds the same as regular steel but put out the toxic/noxious gasses as the galvanized coating is burning. to minimize the fumes you can grind the galvanized coating down to bare steel. also i prefer to use flux core wire instead of solid and shielding gas when welding galvanized steel as im welding outside with a fan blowing...
November 04, 2013, 06:39:36 PM
dburr
« Reply #3 on: November 04, 2013, 06:39:36 PM »
Ryan how about just using cold roll and then covering inside and out with POR15? Galvy is expensive as you know and if the tongue is well coated with a paint like POR15 and able to drain it will last most likely longer then you will keep it.
If you bolt it together then you can dump the paint in the tube, roll it around and end over end to ensure complete coverage and not have to worry about burning the paint off putting it together..  My Yacht Club trailer has a 3x5 tongue that is through bolted in 2 places with 5/8" bolts.. No welds.
 :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
November 04, 2013, 06:45:33 PM
« Reply #4 on: November 04, 2013, 06:45:33 PM »
You have to grind off the zinc before you can weld galvanized steel.  And yes you don't want to breath in any of the fumes!  You can't have a fan on the weld since it will blow away the shielding gases, even with flux core wire.  Best to do it in a very well ventilated area.  The best bet is not to weld at all since once the galvanized coating is damaged there it will begin to rust in that area... no matter what you put on it  your only slowing down the process.  Bolting on a new section would be best.  There has to be a source for a new tube in your area.
November 04, 2013, 07:15:55 PM
« Reply #5 on: November 04, 2013, 07:15:55 PM »
Good advice, and definitely worth keeping. Those old Shoreline's are beasts :thumright:
November 04, 2013, 09:46:40 PM
« Reply #6 on: November 04, 2013, 09:46:40 PM »
Quote from: "wingtime"
Having had this problem I agree, I went with an aluminum tongue but I know guy so the price was right  :wink: finding one local is the way to go if you can, shipping a Galv tongue won't be cheap, long and heavy.
November 04, 2013, 11:24:03 PM
Georgie
« Reply #7 on: November 04, 2013, 11:24:03 PM »
Wow, that's a lot of good info guys! :shock:  Thanks!!  I guess I was a bit remiss by not clarifying that this old trailer has a braced hinge/pivot bracket (rusted, but definitely salvageable) that I'll need to cut off, clean, and re-weld to the aft/rear end of the tongue tube in order for it to be reattached to the frame.  I'll try to add a photo tomorrow when i have my other computer.
Quote
SB - if only that were possible...but the entire aft section is bad from repeated dunking while the forward section is fine.   :evil:
Aaron - thanks man... glad to hear from someone I can trust that the welding galvanized steel is feasible, and a few helpful pointers as well...might save me a few hundred in labor.  My local shop (solid reputation) gets $80/hr but estimates 3 hours for the 6-weld job...  :roll:
Dave - you kill me consistently b/c your knowledge and familiarity with such a huge spectrum of marine arts is as well rounded as anyone I've ever (not quite) met and an embarrassing percentage of what you write is purely Greek to me.  It's not all just Maineiac theory, right??   :lol:  I'm great with wood (Dad's a carpenter), but fairly weak with metals except as far as lathe-turning and general machining goes.  My grandfather was a LIFETIME welder but it was all straight steel and i never got to pick his brain as much as i wanted before he retired and got rid of his equipment.   :(   I'm morbidly ashamed to admit I have NO idea what cold roll is and I have no idea what POR15 is    :oops: ...and I feel foolish researching it now, yet I'm still gonna do exactly that as soon as I'm done with this post.
Quote
Bruce - that was my  exact concern, so I've been inquiring about hot dipping locally, but I asked the local shop and the guy I spoke to said when they weld galvanized, they just coat the fresh welds and burnt areas with cold galvanizing.  I know it seems like a short term answer, but they have an AWESOME reputation so they can't be disappointing too many people I'd think.   :scratch:
Scott - this one has to be steel so I can weld the pivot bracket to it;  I wish though... :|   Will definitely keep digging.  Because of the antiquated design of my tongue and trailer, it's already pretty hard to find the 9 ft. section I need.
I really appreciate the input guys.  Thanks again and keep it coming if anything else comes to mind  :salut:
Just noticed I completely misspelled my thread title...classic.   :pukel:
Ryan
1979 246 CCC
November 04, 2013, 11:30:04 PM
« Reply #8 on: November 04, 2013, 11:30:04 PM »
Failyur...yur kiddin' me...
Living close to the Everglades will do that to you... :thumright:
November 05, 2013, 08:03:20 AM
« Reply #9 on: November 05, 2013, 08:03:20 AM »
Make sure and check with Cliff at B&S trailers. He is one of our vendors. If he doesn't have anything there, he might have a suggestion for a supplier.
352- 912-2161
viewtopic.php?f=12&t=10767
November 05, 2013, 08:09:57 AM
« Reply #10 on: November 05, 2013, 08:09:57 AM »
I have a bunch of experience with cold galvanizing spray.  It is probably the best thing you can put on there next to actual galvanizing.  However even then it will allow rust to form under it over time since all it is is paint with zinc in it.  So you will have to wire brush it and reapply it once or twice a year and in time the welded area will rust.  Like I said with steel your just buying time delaying the inevitable.  Granted the tongue doesn't get dipped in the salt as much as the rest of the trailer so it would take a while.
November 05, 2013, 09:10:08 AM
BStrailer
« Reply #11 on: November 05, 2013, 09:10:08 AM »
Yes please give us a call here @ B&S Trailers. If you give me the size and gauge of the tongue material that you need we can either help you out here or point you in the right direction so that you may complete your repair.  Our phone # here is 352-591-2161
November 05, 2013, 01:13:29 PM
dburr
« Reply #12 on: November 05, 2013, 01:13:29 PM »
My apologies Ryan!!! :oops:
Cold roll is a steel forming process as is hot roll.  The end result is differing steel strengths, the cold roll being not quite as strong but very adequate for a trailer and also common and cheaper.  When working in the trade, that is how some guys refer to it ie cold roll box tube is what you're looking for.
Welding galvanized.  6011 rod will do just fine and will burn through the galvy and produce a bunch of slag and a typical 6011 looking weld. In the shipyard when we welded galvy schedule 40 6 inch pipe on for rail we caps did all the tacking with 6011 and then the welders came behind us and ran wire over it. (Don't remember what wire though).  The welds were then painted.. We wore respirators or made damn sure we were out of the smoke.  If inhaled, nasty hacking for a bit followed by a hell of a headache.. So don't do that.... :wink:
POR15 is probably the toughest coating for auto frames I have ever seen..  Our mechanic built up a 52ish Jeep Willies (sic), his truck and that is the way he spells it, and put that stuff on the frame.  He took great joy in his demo on how tough the paint was.  He'd walk deliberately to his tool box, pull out a ball peen hammer and walk over and whack the TAR out of the frame.. :shock:  :shock:  The hammer would leave a baby elephant track but not damage the paint.  5 years later, after a post mudrun hose off, the paint still looks like it did the day it cured..  I think I'd class that as good stuff..
 :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
November 06, 2013, 11:15:51 PM
Georgie
« Reply #13 on: November 06, 2013, 11:15:51 PM »
Dave - First, don't ever apologize for providing a member with new, quality guidance.  What you wrote is HUGE info for me, so I can only imagine the benefits you can give to our other members...and for me personally, thanks!  One of the biggest things I get from this forum is exposure to techniques, materials, or chemicals my local market and personal experience are not familiar with.  You, however, have an ability to make me feel dumber than anyone I've ever (not quite) met.   :lol:  and I mean that in the MOST appreciative sense.  :salut: The info you provided will be seriously helpful come welding time...and dammit I GOTTA learn to weld.   :x
Lewis - I spoke to B&S and magically they had in stock the tube I need, for the cheapest price I've seen yet, were beyond personable on the phone, and are able to ship to me for only $35-40.   :shock:
Bruce - if I reattach my coupler and pivot bracket to the new tube do you think a healthy dose of cold galvanizing will do the trick?  Any special prep work to make it last or do I just make sure it doesn't sit exposed to air for too long once it's prep'd and ready to go?
decisions...decisions....decisions....
Thanks again,
Ryan
1979 246 CCC
November 06, 2013, 11:41:30 PM
« Reply #14 on: November 06, 2013, 11:41:30 PM »
B&S are really good folks to deal with! It is good to have them as a member here.
I have had really, really good results using this.
http://www.amazon.com/Hammerite-Rust-Pr ... pray+paint
Once this stuff cures it is really tough. It doesn't show much when sprayed over the galvanized. I have had zero areas peel or even get scratched once it is cured. It will go right over any rust and seems like it seals it off and has been working on my trailer for the last 2 years. If you decide to use the galv spray it seems that 3 out of 4 cans lock up in the bottom and you can never get it all out.
