Scotty, did you see the fridge?
The boat will likely be powered by triple 300's.
The extension was created. And, then the inboard stringers were then also created (slightly smaller) and were built three feet forward of the actual extension. Then they were slid inside the existing stringer system like a sleeve. The outboard stringers were also glassed together. The bottom was then glassed three or four feet forward and also to the new stern. The boat will likely be powered by triple 300's.
