Author Topic: Fuel Tank Dimensions  (Read 19015 times)
March 27, 2014, 11:42:54 AM
Re: Fuel Tank Dimensions
« Reply #15 on: March 27, 2014, 11:42:54 AM »
1991 Custom 55 gallon fuel tank.
Note: All dimensions are identical to the original factory tank except overall length, resulting in a reduction of capacity from 100 gals. to 55gals.
May 14, 2014, 01:21:36 PM
Aquasport Commodore
« Reply #16 on: May 14, 2014, 01:21:36 PM »
Custom 90 gal. poly for 1972 22-2 rebuild.
November 10, 2014, 10:33:57 AM
giorgos
« Reply #17 on: November 10, 2014, 10:33:57 AM »
1987 270 TM
Twin gas tanks each one measures:
60" X 33" X 15"    About 128 gallons.
May 22, 2016, 11:54:12 AM
Shavrfillet
« Reply #18 on: May 22, 2016, 11:54:12 AM »
OK FOLKS, Here is my contribution on fuel tanks. this tank if for the 250CCP dont know if other models use this same tank.
May 06, 2019, 03:44:51 PM
TheKid
« Reply #19 on: May 06, 2019, 03:44:51 PM »
Finally yanked my tank.
Here are the dimensions for 1979  222 FFV 85 Gallon.
June 10, 2019, 04:46:47 PM
Starfisher39
« Reply #20 on: June 10, 2019, 04:46:47 PM »
Does anyone have the fuel tank dimensions for a 1987 170 Osprey?  Mine has developed a leak and i need to replace asap!  Thanks!
June 10, 2019, 09:37:08 PM
« Reply #21 on: June 10, 2019, 09:37:08 PM »
Look at Reply #12 above.
September 10, 2019, 05:47:12 PM
hesh
    • heshphoto
« Reply #22 on: September 10, 2019, 05:47:12 PM »
hi!
looking for dimensions / specs for 1997 osprey 175 fuel tank.
also if y'all have recommendation for new sending unit.
thanks!
September 10, 2019, 11:28:37 PM
boatnamesue
  • Jason
« Reply #23 on: September 10, 2019, 11:28:37 PM »
hi!
thanks!
Re: Sender......Digital or Analog?
Depends on your budget.  I'm a simple guy, always used analog float sender.  Super simple.  Super reliable.  Super cheap ($40).  Moehler dominates the market.  Amazon will be cheaper then a marine supply store.
Jason
1976 AS 170
1998 S115TLRW
September 11, 2019, 07:03:19 AM
« Reply #24 on: September 11, 2019, 07:03:19 AM »
We do know that the Factory tank is 33 gals.
You might try contacting  these people. They made tanks for the Genmar hulls and had the cut sheet on my original tank in my 91.
http://www.rdsaluminum.com/marine-custom.html
January 25, 2021, 04:41:44 PM
CTsalt12
« Reply #25 on: January 25, 2021, 04:41:44 PM »
The coffin on my 1989 175 is 60 x 19.5 x 9.5.
The tank I just ordered was 59.6 x 19 x 7, from Phil at Alloy Metal Works in Long Island.
The capacity will be 35 gallons, right in line with the stock fuel tanks on these boats.  It is slightly larger than the 170s 1988 and earlier.
Jimbo
1989 175 Osprey
July 13, 2021, 08:20:29 AM
Dnice
« Reply #26 on: July 13, 2021, 08:20:29 AM »
Hi everyone, i own a 98 explorer my gas tank when on me i live in Rhode Island and was wondering if anyone have an idea where i can get a replacement? My tank sticker saids ins a 141 capacity please let me know thank you!
July 13, 2021, 11:11:21 AM
« Reply #27 on: July 13, 2021, 11:11:21 AM »
Dnice - check out Phil at Alloymetalworks.com.  Close to you.
July 14, 2021, 01:16:48 AM
Dnice
« Reply #28 on: July 14, 2021, 01:16:48 AM »
will do thanks rick!!
January 12, 2022, 10:38:40 AM
cryder
  • 5618183858
« Reply #29 on: January 12, 2022, 10:38:40 AM »
Hi All,  A little late but I did replace the tank on my 1985 196 model which I detailed in the re build section of this but the outside dimensions of the tank I removed (origional?) were 63" x 21" x 8" deep.  I too bought one from Phil at alloy metal and he gave me the best price and it was delivered in tact with no problems what so ever.  His plate was on the one I removed and despite looking dirty was in tact except where the steel reinforcing wire of the fill line had come in contact with the aluminum tank flange and corroded.  The fill hose itself DEFINATELY needed to be, and was, replaced as when I grabbed it to TRY and pull it out it broke.
Chris
