Marc-Nice job! I have been eyeballing that tool at Harbor Freight for while but was not sold on it's usefulness. How did it work on cutting the fiberglass and what blade did you use? I think I may follow in your footsteps on the hatch. The PO removed the pump from the same fish box so I have been contemplating on what to use it for... I never really store fish in there (use front lockers that drain overboard) so I am perplexed. It does not drain well and just collects dirt so I am not sure if I'm keen on buying a new macerator pump ($$). Any suggestions or ideas on utilizing that space?PS- I did see a picture, not sure where, but someone was using it to store their batteries. Not sure I like that idea though.PS - Do want my WEMA sender from my stock tank, free of charge of course? It's barely a year old but I can't use it on my new tank due to the dimension change. Just let me know.B
Bruce, the best thing you can do to help with drainage is to install a drain in the floor of the box like you see in Marc's pic. Pete and I believe also Scott have done the same in their fishboxes. These drains from Marine East...http://www.marineeast.com/a_sch/sch_det ... &pid=02_01 work real well as their flanges are almost flush...route out a bit of the glass where the flange lies and you CAN make them flush.If you want to go the macerator pump route, you'll need a drain with an 1 1/2" barb, every macerator pump that I know of, that's what the inlet port size is, with a 1" discharge port. If you choose to just let it drain into the bilge, than a 3/4" barb drain will do just fine, use a drain plug to cap it off...
