Author Topic: Gas Tank Replacement - Osprey 245  (Read 2830 times)
November 13, 2013, 07:26:29 AM
Reply #30
Bergertime
Re: Gas Tank Replacement - Osprey 245
« Reply #30 on: November 13, 2013, 07:26:29 AM »
Thanks for your input all!  I will drop by there today and have a discussion with him.  Much appreciated.
B
98 245 Osprey / Johnson 225
November 13, 2013, 08:20:56 AM
Reply #31
« Reply #31 on: November 13, 2013, 08:20:56 AM »
Bruce, I'll leave the fuel tank alone (enough has already been said), but I would like to address the non-skid issue.  There are non-skid panels available (Worst even sells repair kits...http://www.westmarine.com/webapp/wcs/st ... oN19NJ2ExE, but larger sheets can be bought from Composites One) that your guy could have used on the new tank hatch, they would have closely replicated the existing non-skid on the rest of the sole.
But in looking at the pics, it appears that a good deal of the pour foam was allowed to drip/spill onto the starboard side sole where they filled the voids through those 1 1/2" holes.  That whole area should have been masked off with at least a double layer of masking paper so as any spills would have been contained and removed.  But now that spilled foam has kicked off and there is no way it is coming off that area short of grinding.  Very very poor preperation for that job, IMO...
November 13, 2013, 09:06:43 AM
Reply #32
« Reply #32 on: November 13, 2013, 09:06:43 AM »
Just so there's no misunderstanding,
You will not be the first member to paint (cold tar) then foam in a new tank. I stated earlier I hadn't seen the fiberglass method but just to offer another option at this stage of the game, you may want to consider just removing the glass from the tank top, leaving the foam covered. If possible, then paint the top. Cold tar is but one option you could use.
The paint on the bottom should offer some buffer between the tank and rubber (if you subscribe to the carbon theory) and keeping the water out (via the tube) of the coffin between bulkheads should help considerably. Remember that not only the foam but the paint itself offers insulation to the tank and therefore greatly reduces the forming of condensation on its outer surface. My opinion is the bulk of corrosion seen on these (aluminum) tanks comes from water that enters the coffin rather than condensation on the surface but that's another story.
Lastly, I would think you could get a fair amount of time out of this install so the the question will be how long do you plan on keeping the hull?
Give it some thought. Only you know how the builder/installer will react and it's not the end of the world as we know it. However you end up, please use the welded tank tab (designed for same) as the bonding point.
November 13, 2013, 10:19:26 AM
Reply #33
« Reply #33 on: November 13, 2013, 10:19:26 AM »
Two different ideas on sealing and not sealing tanks. Nothing wrong with either. Any condensation should form on the glass as that is the contact point with the outside air.
Check out Joel's tank install on his Seacraft. Lots and lots of info and theory about tank installs.
http://forums.bateau2.com/viewtopic.php ... 7&start=70
November 13, 2013, 10:30:11 AM
Reply #34
Bergertime
« Reply #34 on: November 13, 2013, 10:30:11 AM »
Thanks all...  Again, I appreciate the opinions and thoughts.  This boat is maybe a 5 year venture for me with my sights set on something a little larger (26-27 foot) with twins that offers a little more recreational versatility.  At least that is my thought now but who knows.  At the very minimum I will ensure the tank and filler hose are properly grounded for safety purposes.
B
