Author Topic: Porta bracket troubleshooting  (Read 2117 times)
October 16, 2013, 05:13:27 PM
Read 2117 times
melba toast
« on: October 16, 2013, 05:13:27 PM »
Porta folks are closed to Oct 22, or I would have asked them.
I have a 2-3 old portabracket that is not working at all.
(I assume its the trim switch located on the steering wheel)
Its a pretty typical set up with the hydraulic unit and solenoids inside a closed transom, then the hydraulic lines run out the transom to the actuator.
To test the unit, Can I jump the switch by connecting the blue wire (up) or the green wire (down) to the positive battery post ?
If this doesn't work, then I am thinking its likely corrosion on the solenoids located next to the hydraulic unit.
October 16, 2013, 05:48:38 PM
Re: Porta bracket troubleshooting
« Reply #1 on: October 16, 2013, 05:48:38 PM »
Absolutely.  That's how I test the pumps to make sure they're still good.  The Porta-Bracket uses the same pump as a Bob's Jack Plate, the variation of the old tried and true Mercruiser TNT pump.  Just make sure your ground to the pump is good...
October 17, 2013, 03:17:59 PM
melba toast
« Reply #2 on: October 17, 2013, 03:17:59 PM »
It was corrosion on the relays. Jumping it at the solenoid had the bracket working just fine. I may clean them up and try to use them or buy some new ones depending on price. I am going to be installing this unit on my boat eventually so I may start with fresh components.
The unit is only 2-3 years old, but the solenoids are inside an enclosed transom cap, with moisture from the bilge and gulf coast humidity working on them. I would recommend corrosion block, ect on all connections for anybody who has a bob's or a porta with this type of set-up.
October 17, 2013, 03:25:41 PM
« Reply #3 on: October 17, 2013, 03:25:41 PM »
Contact Porta.  Betcha they'll send you a couple new ones...maybe even free... :wink:
Another thing I would do before installation is drain and clean the pump reservoir.  I have done a TON of Bob's pumps (same pump) where the oil is just gross, almost to the point where you think...how does this jack plate still work?
