Author Topic: Installation of secondary bilge pump  (Read 427 times)
October 15, 2013, 07:11:17 PM
Read 427 times
pmoat
« on: October 15, 2013, 07:11:17 PM »
I am planning on installing a backup/secondary bilge pump.
Can it share a drain line with the primary bilge or do I have to make an additional penetration for another bilge line in the hull.
New owner of a Model: "188 O/B FF"
October 15, 2013, 09:47:28 PM
Re: Installation of secondary bilge pump
« Reply #1 on: October 15, 2013, 09:47:28 PM »
If, for some reason you need to run both at the same time (emergency) then yes because you will end up restricting both pumps.
Planning on placing a Y connection at the thru hull?
I see a lose of efficiency with water entering the non running line.
The more I envision it, without some form of valve to prevent water from backing into the other hose, it's a poor design at best but with say a diverter type valve, it might work OK.
http://www.westmarine.com/webapp/wcs/st ... l3wERDpzkA
Still seems like a PITA to me but.......
October 15, 2013, 10:15:33 PM
« Reply #2 on: October 15, 2013, 10:15:33 PM »
Second discharge t/hull a must.  Don't sugar coat it CB... :thumright:
October 16, 2013, 06:27:07 AM
« Reply #3 on: October 16, 2013, 06:27:07 AM »
Second Don't sugar coat it CB... :thumright:
I can't help it.
It's the new me. :oops:
October 16, 2013, 08:25:58 AM
« Reply #4 on: October 16, 2013, 08:25:58 AM »
Uh, yeah, right Bob.  We know you only too well... :wink:
