Author Topic: Drain pipes for 2000 Aquasport 21'9" Model 205  (Read 467 times)
September 27, 2013, 11:19:16 AM
Read 467 times
Ms Loretta
« on: September 27, 2013, 11:19:16 AM »
My 25 foot deep V Appolo I/O sunk at the dock after having her for 38 years. So I have just
purchased a 2000 Aquasport 21'9" Model 205 Hull ID AQABUB1C000 with a Johnson outboard.
Now my question is, Aquasport sold out to Wellcraft and I just can't figure out where the drain pipes are located under the deck in case they are blocked with leaves etc. so I can clean them out. I am
not used to such a shallow vessel and was wondering if anyone can help me. Would someone have a diagram under the floor board of this vessel. Many thanks for your help in this matter
September 27, 2013, 11:24:43 AM
Re: Drain pipes for 2000 Aquasport 21'9" Model 205
« Reply #1 on: September 27, 2013, 11:24:43 AM »
Does it look similar to this model?
September 27, 2013, 11:50:58 AM
« Reply #2 on: September 27, 2013, 11:50:58 AM »
If your boat is the 205 Osprey like Capt Bob posted your cockpit drains should be located in the aft corners of the deck.  They should have a hose that connects to a thru hull fitting just above the water line below the "T" in Aquasport in the pic below.
BTW  Welcraft didn't own Aquasport.  Welcraft, Aquasport, Hydrasports and others were owned by a parent company called Genmar.   Aquasports were built in the same Sarasota plant as Welcraft until Genmar closed that plant and moved Welcraft production up north and they shelved the Aquasport brand.
September 27, 2013, 11:53:40 AM
« Reply #3 on: September 27, 2013, 11:53:40 AM »
I would suggest you open the starboard side access door, stick your head in there, and look down and to the left...
September 27, 2013, 06:39:14 PM
« Reply #4 on: September 27, 2013, 06:39:14 PM »
Craig to the white phone....
October 05, 2013, 07:35:00 PM
« Reply #5 on: October 05, 2013, 07:35:00 PM »
Quote from: "RickK"
LOL!  Sorry for the delay, I just saw this thread.  I can really add much more than has already been said.  Cockpit drains are in the rear corners, with a short length of hose to the side-mounted thru hull fittings.  They do clog a bit if you get a lot of leaves in the boat.  I take a water hose and blow out the lines once in a while.  For stubborn clogs you may need to blow it out from the outside.
