Author Topic: Lowrance X26SCLHD  (Read 557 times)
September 19, 2013, 03:57:38 PM
Read 557 times
Conga aquasport
Lowrance X26SCLHD
« on: September 19, 2013, 03:57:38 PM »
:afro:
I have that GPS and i cant get it to work. It tells me that it can not read the GPS module. I wired and had my mech friend at Sunshine Marine in Miami, fl try and wire it also. Any suggestions?
September 19, 2013, 04:30:01 PM
Re: Lowrance X26SCLHD
« Reply #1 on: September 19, 2013, 04:30:01 PM »
Is it this model? :scratch: It does have most of the numbers and letters, just not in the order you show.
http://www.fishfinder-store.com/lolchdsogpsc.html
I'd start here.
http://support.lowrance.com/system/self ... cure=false
September 19, 2013, 04:41:28 PM
« Reply #2 on: September 19, 2013, 04:41:28 PM »
Conga, is it the same model in the link Capt. Bob posted above?  If so, did you buy new or used?  If used, the antennas for those models are know to go bad. I recommend trying with a different antenna to see if that corrects the problem. Good luck.
September 19, 2013, 06:08:56 PM
« Reply #3 on: September 19, 2013, 06:08:56 PM »
Following that thought, note that the second link has several troubleshooting tips related to antenna selection.
We may be on to something here.
September 19, 2013, 07:51:56 PM
Capt Matt
« Reply #4 on: September 19, 2013, 07:51:56 PM »
Was a constant never ending problem on lowrances I owned over about 6yrs never had one of ten plus units last longer than about 6 months It happened with both built in antena and external antena units "GPS module not responding"
 I had two units and one was always in the mail, they would simply send back a recconditioned unit. When they changed to a new model they wanted me to pay to upgrade so I bought a Garmin
Think when they switched to the new style units it finally did solve the problem (poorly sealed unit h2O damage, moisture)
Send it back to lowrance if you registered it and they will pro rate a new model.
 BRP owners lowrance makes your digital gauges
Capt Matt
Light tackle sportfishing
September 19, 2013, 08:55:23 PM
« Reply #5 on: September 19, 2013, 08:55:23 PM »
Quote from: "Capt Matt"
Capt Matt
Go with the professional guide's advice. Get a new Garmin.
September 21, 2013, 07:58:55 PM
« Reply #6 on: September 21, 2013, 07:58:55 PM »
Only Lowrance GPS antennas will work with the LCX series...and they are pricey.  I tried wiring in a Garmin puck, a Raymarine puck...no dice.  Basically, unless you just want to use it as a stand alone FF, might as well chuck it and follow Scott's advice... :thumleft:
