Other Classic Rebuilds
Fletch's Hydra Sport 2100 CC
10
11
12
13
17
Topic: Fletch's Hydra Sport 2100 CC (Read 17681 times)
August 14, 2015, 09:27:28 AM
Reply #150
Fletch170
Reply #150 on:
August 14, 2015, 09:27:28 AM »
1981 2100 CC Hydra Sport
1976 170 (sold)
August 14, 2015, 10:39:36 AM
Reply #151
Reply #151 on:
August 14, 2015, 10:39:36 AM »
Looks like you're getting close to buttoning her back up. Lookin good Fletch
August 18, 2015, 04:25:40 PM
Reply #152
Fletch170
Reply #152 on:
August 18, 2015, 04:25:40 PM »
Thanks Rick, still have a ton of work before she gets off to paint this winter. I really thought I'd have it done for the fall, but if I'm being realistic, I don't think it's going to happen. I'm just taking my time and doing it to the best of my abilities.
The only thing I'm farming out is the paint (I'll prime it), and the starboard work for the doors and rod storage trim.....all of which will be done in a heated shop during the winter months.
1976 170 (sold)
September 01, 2015, 12:05:28 PM
Reply #153
dixoncj
Reply #153 on:
September 01, 2015, 12:05:28 PM »
Hi Fletch - I just found this thread with The Google and signed up for this forum because of it. I have a 1985 Hydrapsorts 2100cc - the actual boat I used to fish on with my granddad as a teen. Been doing a lot of work on it - including the transom a couple years ago. I got rid of the 2thirsty5 and put a 1999 200 Ocean Runner on it and it drives niiiice. Havent' taken the decking off or anything - and after seeing this thread, I don't plan to. Polished it up a few weeks ago and it looks fairly stunning - particuarly the glitter in the 'lightning bolt'. This is a pre-polish pic. Will post some more up near future.
If you ever find a brochure or owners manual, I'd sure love to see it!
CD
http://chrisdixonreports.com
September 16, 2015, 01:53:32 PM
Reply #154
Boatdesigner
Reply #154 on:
September 16, 2015, 01:53:32 PM »
Haven't been here in a while, but thought I should mention something. In your old stringer system, the wood was the structural component, not the fiberglass. It has to do with the relative stiffness of the two materials. With the foam cored stringers, the foam is essentially just a form for the fiberglass, which is now carrying all of the structural loads. You need to make sure you have enough glass to support the loads. Just off the top of my head, I would have used 3 layers of 1708 0/90 material or two layers of 2415 fabmat. You also need to make sure you wrap the top of the stringers with glass as that ties the two sides together and creates a beam. Some people will overlap the two sides at the top to make it extra thick and strong. It looks like your boat is coming along nicely, great job!
September 16, 2015, 06:49:59 PM
Reply #155
Reply #155 on:
September 16, 2015, 06:49:59 PM »
Nice explanation and analysis BD
Thanks for hanging out with us
September 24, 2015, 11:54:23 AM
Reply #156
Fletch170
Reply #156 on:
September 24, 2015, 11:54:23 AM »
Hey all! Back on track with this build. Finally got the stringers done, and have started installing the rigging tube. I will follow up with pictures as soon as I can!
Chris, I'm glad you found this! There really isn't much out there in the way of information for these boats. BD sent me most of what he had. Shoot me your email and I'll forward over what I have.
1976 170 (sold)
September 24, 2015, 11:59:38 AM
Reply #157
Fletch170
Reply #157 on:
September 24, 2015, 11:59:38 AM »
Also, as I put the deck down, I will be (outside of using a ton of putty), will be tabbing the deck to the stringers from the bottom side.
1976 170 (sold)
September 28, 2015, 10:10:19 AM
Reply #158
Fletch170
Reply #158 on:
September 28, 2015, 10:10:19 AM »
1976 170 (sold)
September 28, 2015, 06:04:35 PM
Reply #159
Fletch170
Reply #159 on:
September 28, 2015, 06:04:35 PM »
1976 170 (sold)
September 28, 2015, 06:53:12 PM
Reply #160
Reply #160 on:
September 28, 2015, 06:53:12 PM »
Nice progress Fletch
What are you going with for the tank - poly?
September 28, 2015, 07:19:26 PM
Reply #161
Fletch170
Reply #161 on:
September 28, 2015, 07:19:26 PM »
Yep! 85 gallon poly. I wish it was bigger....especially with the 225 Carb merc, but it will do. I still cant get a good burn rate from things I read on the internet....so I guess I'll have to do the work myself:)
Advice for anyone who is building stringers that are not foam filled: Allow 4 times the time and resin......What a pain in the rear that was.
1976 170 (sold)
September 28, 2015, 07:44:25 PM
Reply #162
Reply #162 on:
September 28, 2015, 07:44:25 PM »
Looking good Fletch
Just a reminder to those of you installing poly tanks (which is also what I am doing). Make sure you leave enough room on all sides and above the tank for expansion. The tank will expand 2-4% (IIRC) in all directions once the poly reacts with gas. In your setup above, if those ribs are snug against a brand new poly tank, it might not be pretty once the tank expands. You may be aware of this already, but I figure I would bring it up just in case....
September 29, 2015, 11:07:00 AM
Reply #163
Fletch170
Reply #163 on:
September 29, 2015, 11:07:00 AM »
Thanks for the heads up. I'm aware the tanks expand, so there is some room for said expansion.
1976 170 (sold)
October 09, 2015, 02:34:28 PM
Reply #164
Fletch170
Reply #164 on:
October 09, 2015, 02:34:28 PM »
1976 170 (sold)
10
11
12
13
17
