Author Topic: Fletch's Hydra Sport 2100 CC  (Read 17608 times)
October 09, 2015, 09:47:19 PM
Reply #165
Que Pasa
  • NorthEast
Re: Fletch's Hydra Sport 2100 CC
« Reply #165 on: October 09, 2015, 09:47:19 PM »
Fletch, how did you like the corelite. Are you doing your floor with it?
October 14, 2015, 10:26:49 AM
Reply #166
Fletch170
« Reply #166 on: October 14, 2015, 10:26:49 AM »
The corelite stuff is awesome. As I've stated before, there is no good reason to use anything else. Just as good as Coosa, and easier to work with. At a price point that for literally a few extra bucks, Marine Plywood would be foolish. I bought mine from Barnegat Light Fiberglass Supply.....great guys. I think it was $140 bucks a sheet.
I see you are in Somers Point, where I do all my boating. When she is done, you can see her in the C-Jam marina. Joe from Signature fiberglass will be painting it this winter.
-Christian
1981 2100 CC Hydra Sport
1976 170 (sold)
October 16, 2015, 08:50:10 AM
Reply #167
Fletch170
« Reply #167 on: October 16, 2015, 08:50:10 AM »
1976 170 (sold)
October 16, 2015, 09:00:18 AM
Reply #168
Fletch170
« Reply #168 on: October 16, 2015, 09:00:18 AM »
Made some progress today.
Made a few sheets for the rear storage doors, and built the splash well that will be glassed into the 3rd decking sheet.
1976 170 (sold)
October 16, 2015, 09:57:42 AM
Reply #169
Fletch170
« Reply #169 on: October 16, 2015, 09:57:42 AM »
Question for you guys: I'll be cutting the sheets to fit the holes so to speak. What is the best way to install the glass patch panels? For the console, I'm going to use some scrap plywood, and on the front, drill through the console and the patch panel, using the plywood to hold the panel flush. At that point, I'll tab it in from the back. However, I will not have access to the back for the rear storage area. What is best practice for installing the panels where there is no access from behind? Should I consider installing butt blocks? Any insight is greatly appreciated!
1976 170 (sold)
October 16, 2015, 12:15:54 PM
Reply #170
dirtwheelsfl
« Reply #170 on: October 16, 2015, 12:15:54 PM »
The spaces in the very rear right?    Looks like you could glue cleats to the transom and around the perimeter maybe?
Are you going to be putting access plates in those spots?   If so you could just hot glue gun some temporary cleats in there and knock em out after you've got the filler pieces all tabbed on the outside. Then tab the inside thru your access holes.  Either way!
October 16, 2015, 05:11:46 PM
Reply #171
Fletch170
« Reply #171 on: October 16, 2015, 05:11:46 PM »
Hey man, Yes there will be your run of the mill PVC hatches for access.
Looks like the tabs is the ticket. Thanks brother!
1976 170 (sold)
October 21, 2015, 09:10:50 AM
Reply #172
Fletch170
« Reply #172 on: October 21, 2015, 09:10:50 AM »
1976 170 (sold)
October 21, 2015, 09:23:01 AM
Reply #173
Fletch170
« Reply #173 on: October 21, 2015, 09:23:01 AM »
Well, that was fun. Got her foamed in. However, put way too much foam in the port side of the boat. The interesting part of LxWxH in a deep v boat, you need to measure in the center of the cavity, not the deepest part (which is obvious now, I just wanted to make sure I ordered enough. Soooo things got pretty out of hand when the foam expanded:) As you can see, it pushed the fill line and vent line up above where the deck would be. SOOO, had to painstakingly remove the foam around the lines without damaging them.
Got the patch panel in the console, and I'm very happy with the results. For that, I actually put the console on it side on the flat ground, put a car battery on the back of the panel to keep pressure, and tabbed around the edges. Worked really really well!
The key was my key to my Dad's house, foamed it into the starboard side. I guess the idea is that I'll always be "home" on the boat.
1976 170 (sold)
October 21, 2015, 12:09:50 PM
Reply #174
dirtwheelsfl
« Reply #174 on: October 21, 2015, 12:09:50 PM »
Comin together!    Cleats looks good  :great02:
October 21, 2015, 01:06:16 PM
Reply #175
« Reply #175 on: October 21, 2015, 01:06:16 PM »
Yeah that foam has a mind of it's own sometimes  :41:
October 22, 2015, 09:18:51 AM
Reply #176
Fletch170
« Reply #176 on: October 22, 2015, 09:18:51 AM »
Got myself a nice new pull vehicle. Should do the trick:)
1976 170 (sold)
October 22, 2015, 11:25:53 AM
Reply #177
« Reply #177 on: October 22, 2015, 11:25:53 AM »
 :thumleft:
October 23, 2015, 10:50:13 AM
Reply #178
Fletch170
« Reply #178 on: October 23, 2015, 10:50:13 AM »
Does anyone make a "drop in" anchor locker like this? I don't want my anchor in the bow just flailing all over.
1976 170 (sold)
October 23, 2015, 11:37:03 AM
Reply #179
« Reply #179 on: October 23, 2015, 11:37:03 AM »
This topic has been broached before and the results weren't promising.
http://classicaquasport.com/smf/index.php?topic=5027.0
Rebuilding the forward section of the cap would be the time to construct a custom model.
Can't recall anyone attempting it as of now.
Good luck. :thumright:
