Author Topic: grounding fuel filler line  (Read 374 times)
September 01, 2013, 10:52:06 PM
Read 374 times
love2fish
« on: September 01, 2013, 10:52:06 PM »
I am about to change out my Fuel fill hose and deck cap. I pulled the old hose out today and noticed there is a ground wire that is twisted around the metal wire that wraps the hose- this is then attached to the bolt that holds the fuel fill cap to the deck.
Is this necessary for the new hose and cap i plan to install?
Chris
\'74 22-2
Member #921
September 02, 2013, 06:33:14 AM
Re: grounding fuel filler line
« Reply #1 on: September 02, 2013, 06:33:14 AM »
Chris, I would run a grounding wire from the fill to the grounding tab on the fuel tank, then from the grounding tab to your grounding bus bar or directly to the battery.
September 02, 2013, 10:30:10 PM
love2fish
« Reply #2 on: September 02, 2013, 10:30:10 PM »
thanks Nando! I had the gas tank grounded directly to the battery and today ran a ground from the deck fill to the ground tab on the tank- so now the fill and tank are both grounded to the battery.
Chris
\'74 22-2
Member #921
