Author Topic: Fuel Tank Bonding  (Read 385 times)
August 23, 2013, 09:18:31 AM
Read 385 times
hydraulicane
Fuel Tank Bonding
« on: August 23, 2013, 09:18:31 AM »
hey capt.
when we were talking about ground my fuel tank,
I believe you said you ground yours to the neg. side of your battery.
and said it was a frowned upon practice.
i'm a little curious as why thay would be.
Hydraulicane
August 23, 2013, 09:48:13 AM
Re: capt. bob
« Reply #1 on: August 23, 2013, 09:48:13 AM »
I think the general rule of thumb is to limit connections to battery posts to the main cables themselves and a smaller gauge feed to your negative buss in the helm. Maybe it's best practice to terminate all grounds through the buss and limit excess connections at the battery post. The CG says:
"Grounding or bonding may be accomplished by connecting the metallic components electrically by running a wire from one component to the next, and so forth to the boat’s ground. Grounding can usually be accomplished by a connection to the common bonding conductor or the engine negative terminal".
That to me would indicate (on an outboard) that the negative buss should be established from the engine ground to the helm. I'm probably mistaken but it sounds that way. I know I don't have it wired like that.
I have two on my battery, one for the buss and one for the tank.
