Author Topic: engine and prop question  (Read 683 times)
August 23, 2013, 08:13:27 AM
Read 683 times
sonny200ccp
« on: August 23, 2013, 08:13:27 AM »
i have a 1984 200ccp, it has an older 2 stroke mercury 115 on it. what prop should i run? it didnt have a prop when i bought it.
August 23, 2013, 08:37:21 AM
Re: engine and prop question
« Reply #1 on: August 23, 2013, 08:37:21 AM »
Start with this post and go down (but for the full Monty read the entire thread). :idea:
viewtopic.php?p=43822#p43822
JD's post is from his older 200CCP (don't be confused by his sig at the bottom). Wing's is an EX but it is the same hull as yours and both his and GF's are your hull with bigger Mercs on the transom. Seems your HP is a little low for that hull but it is what it is.
August 23, 2013, 08:56:15 AM
« Reply #2 on: August 23, 2013, 08:56:15 AM »
Quote from: "sonny200ccp"
4 cylinder or 6 cylinder 115? Big difference on how you prop them.
August 23, 2013, 08:59:39 AM
« Reply #3 on: August 23, 2013, 08:59:39 AM »
My 200XF started out with a 125 Force on the back of it.  I think I had a 15" pitch prop on that thing.  I had to really run that thing hard to get that boat going with that Force.  But I doubt that thing was putting 100 HP to the prop.  Also that boat was HEAVY.  I think she had some wet foam in the stringers.   Your 200CCP is the same hull but with a different cap that probably weighs quite a bit less than the 200XF.
Fitz has a good point on the number of cylinders.  The six cylinder wold have MUCH more torque.
August 23, 2013, 03:47:11 PM
« Reply #4 on: August 23, 2013, 03:47:11 PM »
Quote from: "wingtime"
Bruce, believe it or not the 4 cylinder 115 from '89-'05 made alot more bottom end torque than its earlier 6 cylinder brother. The I4 was 113 cu in and the I6 was 99 cu in. Peak power was @4750-5250 for the 4 and @5700-6000 for the 6. So believe it or not the I4 will actually turn a higher pitch than the I6 which is why I asked the question.
August 24, 2013, 11:49:35 AM
sonny200ccp
« Reply #5 on: August 24, 2013, 11:49:35 AM »
1984 mercury 115 6 cyl and i've tried a 19,17. im going to try an 11 next.
August 24, 2013, 12:17:56 PM
sonny200ccp
« Reply #6 on: August 24, 2013, 12:17:56 PM »
by the way so far i cant even leave the harbor yet.
August 24, 2013, 02:12:07 PM
« Reply #7 on: August 24, 2013, 02:12:07 PM »
What is your full throttle rpm's with the 17P?
August 24, 2013, 03:11:33 PM
sonny200ccp
« Reply #8 on: August 24, 2013, 03:11:33 PM »
i cant get to wop. it will die first.
August 25, 2013, 02:35:26 PM
sonny200ccp
« Reply #9 on: August 25, 2013, 02:35:26 PM »
ive made progress today! it started to die at about 10 mph so i choked for a second and it
took off with power and kept the power. i can over rev my 115 hp merc with the 11 pitch so
im putting the 17 back on and going back to the harbor. i will let you know what happens.
August 28, 2013, 08:21:13 AM
sonny200ccp
« Reply #10 on: August 28, 2013, 08:21:13 AM »
i figured out that i dont have a prop problem, i have a fuel delivery problem. thank you for your
suggestions.
