Author Topic: Fish wells  (Read 359 times)
August 08, 2013, 07:09:03 PM
Read 359 times
Dsea7
Fish wells
« on: August 08, 2013, 07:09:03 PM »
My fish wellson thefloor of my 26 ft tournament has a screen on the drain. I would like to keep the fish in there until end of day with water. However the water keeps escaping from the wells. Should I unscrew the screen and plug it up? Thanks.
August 09, 2013, 08:19:30 AM
Bergertime
Re: Fish wells
« Reply #1 on: August 09, 2013, 08:19:30 AM »
Dsea,
Some pictures would help but if your fish box is similar to mine (I have a different boat) it used to have a macerator pump and hose which pushed the water and ground contents overboard through a through-hull fitting at the stern.  However, on my boat the PO removed this pump and my box now drains directly into the bilge area.  I just use for storage but I have two large fish boxes in the front.
Without knowing what lies beyond your screened drain hole, and to directly answer your question... I would refrain from both removing the screen and/or putting fish in there if it drains into the bilge area.  That is a sure fire way to ensure your below deck area will seriously stink due to the left over water and other chit that comes out of a fish after they are caught.
If you are dead set on putting live or dead fish in there I would restore it to what was the likely the factory setup where a macerator pump and hose disposes of the waste and water from the box.  If kept screened you could likely get away with a non-macerator pump as the screen would keep the particulate from the pump.  But either way I would want the fishy chit pumped out.
Just a couple thoughts.. I think the group will need more info to give you a definitive recommendation.  Pictures are always a plus.. Good luck.
B
98 245 Osprey / Johnson 225
August 09, 2013, 03:59:49 PM
Dsea7
Re: Fish wells
« Reply #2 on: August 09, 2013, 03:59:49 PM »
Thanks. I will check to see exactly where that water goes. I have a explorer 250, 26.1 tournament master.I just joined this site yesterday and do not know how to post pics up yet. Thanks for your help I appreciate it.
