If I find the issue.. well that is good news :) However.... if all the lines are delivering fuel from the primer pump what is my next likely suspect? I know that spark plugs and the battery were both mentioned.. Keep in mind that in all cases the motor starts right up after it's run for 5 min and runs perfect. Thoughts on my next likely suspect??
Try keeping your engine tilted up on the initial start. Tilt down the engine just enough to have the water intake and prop under the water. This works for me, first turn every time. If I tilt it all the way down on a cold start it always has trouble starting.
