Overkill would of been spending $25,000 on a new cummins marine 370 hp engine, this will end up being 1/3 rd the price of a new 200 hp outboard, will get close to twice the fuel economy and will last 15,000 hrs and the boat was free.... and i have 5 other cummins... what else was i supposed to do..!
it would of been much easier to simply bolt on an outdrive but so far the volvos and mercruisers are not built to hold up behind the 6bt, even the bravo II X Diesel isnt up to the task, the yanmars are smaller and higher revving engines and dont have the low end grunt of the cummins.... and besides at some point this boat will live in the water in the sea of cortez and outdrives, even though they tolerate sea water, dont hold up like a good shaft and prop.Overkill would of been spending $25,000 on a new cummins marine 370 hp engine, this will end up being 1/3 rd the price of a new 200 hp outboard, will get close to twice the fuel economy and will last 15,000 hrs and the boat was free.... and i have 5 other cummins... what else was i supposed to do..!
this boat was designed for about 475 lbs to be hung on the transom not 1500 lbs in the middle of the boat, Originally the boat was designed for about 1000lbs Motor and fuel. Your going to be over that with no fuel.
I like the idea. As for structural integrity. I think it will be stronger enough. I think you will tie the motor mounts into the stringers their by spreading out the motor weight and the tunnel its self will add to the structural integrity of the hull. It will be like adding a large rib. This will be interesting to watch. I do have a question. With the motor, drive and tunnel, where will the fuel tank go and how large will the tank be?
