Author Topic: ?? 19-6 Performance W 115  (Read 668 times)
July 28, 2013, 08:39:12 AM
Read 668 times
Dannys Dream
« on: July 28, 2013, 08:39:12 AM »
I am looking to put a 115 Yamaha 2 stoke on my 19-6 what kind of numbers can I expect ??
Top speed / Cruse speed / Fuel burn ???
Anyone have similar set up ?
1973 19-6  <%><
July 29, 2013, 10:54:09 PM
fishboy316
  • Mid Atlantic
Re: ?? 19-6 Performance W 115
« Reply #1 on: July 29, 2013, 10:54:09 PM »
I had a 115 johnson on mine and she was a pig! maybe 30 on top end.Older motor but still slow. Put a 150XR4 on and woke that bad girl up! Can cruise at 40 all day and and tops out at about 45-47mph with top.
July 30, 2013, 12:03:34 PM
tmyers
« Reply #2 on: July 30, 2013, 12:03:34 PM »
I have an F115 and a T-top and cruise around 27mph  WOT 34-36.  I am going to put a 150  on when i get the chance.
July 30, 2013, 09:53:25 PM
« Reply #3 on: July 30, 2013, 09:53:25 PM »
The boat was originally rated for 185 hp.  150 hp would do well.
July 30, 2013, 11:37:44 PM
« Reply #4 on: July 30, 2013, 11:37:44 PM »
July 30, 2013, 11:49:54 PM
« Reply #5 on: July 30, 2013, 11:49:54 PM »
Quote from: "tmyers"
If your ride is dry internally (transom, stringers, deck) she should be a ball 'o fire with a Yammie F115. Research your prop....keep that new motor money in your pocket :thumright:
July 31, 2013, 08:47:07 AM
MarshMarlowe196
« Reply #6 on: July 31, 2013, 08:47:07 AM »
A member here named fishcole claimed 40mph+ with a Yamaha F115. For the sake of conversation, some years had lower max HP ratings. My old 73' was rated for 140HP
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
August 01, 2013, 05:55:12 AM
Dannys Dream
« Reply #7 on: August 01, 2013, 05:55:12 AM »
Thanks for all the input and @ Marshmarlow isn't the F115 a 4 stroke 440 lb engine ?  That being said I am looking at trying to find a 130HP 2 stroke that should be in the 370 lb range. I am thinking 29-31 cruise and 40 WOT with the correct wheel. Those numbers I would be Happy with... I was told by a local boat builder that the problem with putting new motors that match max HP rating on older hulls is that they were rated different and it over powers the hull resulting in damage to the stringers / transome.
1973 19-6  <%><
August 01, 2013, 09:10:52 AM
fishboy316
  • Mid Atlantic
« Reply #8 on: August 01, 2013, 09:10:52 AM »
Yeah the older ones were hp rated at the powerhead and the new ones are at the prop. Big difference!
