Author Topic: 1988 Aquasport 222 rebuild  (Read 14629 times)
April 02, 2014, 10:17:31 PM
Reply #75
fishinonthebrain
Re: 1988 Aquasport 222 rebuild
« Reply #75 on: April 02, 2014, 10:17:31 PM »
Quote from: "jmr1"
Yeah she's coming along well right now. Hope to have her in the water by mid July but not going to rush anything if it's not.
Yeah that 20ccp is a buddy's of mine we have been messing with a little. Been sitting for 5+ years. It's not getting a rebuild he doesn't have the money and I'm not sure if I can do another one..... The 222 Aquasport isn't anywhere near as bad as my 1965 Bertram 20 was!!!!
Drains are going to be plumbed under the deck and through the transom and most likely have a check value.
Just need to finish glassing the transom and just put knees under the cap along the sides hope to get it all done this week and flip it next week to gel bottom and sides. Went to home depot  and got some color samples so I can figure a color out.
When you do your drains please show some pictures and what parts you used to create them. I am in the same process right now on my rebuild. Need some ideas. :mrgreen:
1987 222CCP current rebuild.
April 11, 2014, 08:12:45 PM
Reply #76
jmr1
« Reply #76 on: April 11, 2014, 08:12:45 PM »
Got the boat flipped and ready to sand and paint..
April 11, 2014, 08:48:07 PM
Reply #77
« Reply #77 on: April 11, 2014, 08:48:07 PM »
These hulls are just as nice looking upside down! (as long as they are not in the water that way) LOLOLOL!!! :cheers:
Good to have the heavy equipment to help flip!!!
April 28, 2014, 04:42:14 PM
Reply #78
jmr1
« Reply #78 on: April 28, 2014, 04:42:14 PM »
Fairing away and sprayed the bottom with gel. Waiting on the color to come in and going to spray the sides and transom. Then off to wet sanding and buffing.
April 28, 2014, 06:19:08 PM
Reply #79
« Reply #79 on: April 28, 2014, 06:19:08 PM »
Bottom looks good  :salut:
Going with gel all the way?
April 28, 2014, 08:40:22 PM
Reply #80
jmr1
« Reply #80 on: April 28, 2014, 08:40:22 PM »
Thanks. I think so was going to paint the inside but after working with gel after everyone says it's a pain I was happy with how it cam out. So just hope the sides and inside come out as good as the bottom.
April 29, 2014, 05:28:03 AM
Reply #81
« Reply #81 on: April 29, 2014, 05:28:03 AM »
What process did you use with the gel?  Any additive?
April 29, 2014, 10:51:59 AM
Reply #82
jmr1
« Reply #82 on: April 29, 2014, 10:51:59 AM »
This is the clear I mixed in it made it spray like paint. I mixed it 50/50% with gel. Not the cheapest stuff out there. But for never spraying gel and hearing how bad it is and just to paint everything and roll the bottom....... I liked it a lot and happy with the turn out.
April 29, 2014, 07:06:00 PM
Reply #83
« Reply #83 on: April 29, 2014, 07:06:00 PM »
What kind of gun?
April 30, 2014, 11:32:04 AM
Reply #84
jmr1
« Reply #84 on: April 30, 2014, 11:32:04 AM »
Used this gun I got from Fiberlay.
April 30, 2014, 05:54:29 PM
Reply #85
fishinonthebrain
« Reply #85 on: April 30, 2014, 05:54:29 PM »
What did you use for fairing?
May 01, 2014, 09:41:12 AM
Reply #86
jmr1
« Reply #86 on: May 01, 2014, 09:41:12 AM »
AdTech P-77. Was easy to work with except not much work time (4-6 Minute work life) was easy to sand in 15 minutes. Found out the hard way you want to sand it within 24 hours after that it was a lot harder to sand.
May 06, 2014, 02:11:58 PM
Reply #87
jmr1
« Reply #87 on: May 06, 2014, 02:11:58 PM »
Sides and bottom are all painted!! Hope to get it sanded and buffed by the end of the week the flip her and back to fairing.
May 06, 2014, 06:09:02 PM
Reply #88
« Reply #88 on: May 06, 2014, 06:09:02 PM »
Nice  :salut:
May 06, 2014, 06:34:09 PM
Reply #89
« Reply #89 on: May 06, 2014, 06:34:09 PM »
So, is that gel or paint?
Whatever it is, it does look nice!
If it is gel how many mils did you end up with?
