Author Topic: 1988 Aquasport 222 rebuild  (Read 13499 times)
July 24, 2013, 05:34:36 PM
Read 13499 times
jmr1
« on: July 24, 2013, 05:34:36 PM »
Just started my 222 Aquasport most of the demo is done will be starting transom and deck in the next few weeks.
July 24, 2013, 06:24:26 PM
fishinonthebrain
Re: 1988 Aquasport 222 rebuild
« Reply #1 on: July 24, 2013, 06:24:26 PM »
Moving along nice. Welcome.
1987 222CCP current rebuild.
July 27, 2013, 02:58:36 PM
OldSkool67
« Reply #2 on: July 27, 2013, 02:58:36 PM »
Well your off to a good start! Keep the post and pictures coming.  :salut:
Ive never met an alligator I didnt want to turn into a wallet and side of nuggets.
67 flatback
August 03, 2013, 03:45:55 PM
budmanbud
« Reply #3 on: August 03, 2013, 03:45:55 PM »
Thanks for showing us what the insides of one of these 222's actually looks like with the deck removed! Hope your project is coming along nicely.
Is there a trick to posting your pictures in your posts full-size as you have done; I couldn't seem to figure out how to do that; pics I tried to add to my posts ended up being thumbnail sized.
Bud Calloway
Pine Island FL
1986 222 being modified
August 03, 2013, 07:44:16 PM
jmr1
« Reply #4 on: August 03, 2013, 07:44:16 PM »
Thanks... I now have everything grinded and ready for glass. Hope to get time to do the transom this week and the start the deck. I will have more pictures soon. I take all my pictures with my iPhone and put them in photo bucket and link them over.
August 04, 2013, 01:00:57 AM
« Reply #5 on: August 04, 2013, 01:00:57 AM »
Quote from: "budmanbud"
Bud Calloway
Pine Island FL
Bud, if you're using our photo gallery there are two links that you can copy and paste - one is thumbnail, the one below that is the full size.
You can also add the text you have at the bottom of your post to the "signature" entry in your "user control panel". To get there click on the link to the right just below the teal bar above the topics.  This will add it to all your posts automatically.
August 04, 2013, 12:38:01 PM
budmanbud
« Reply #6 on: August 04, 2013, 12:38:01 PM »
Many thanks for your advice, Rick. I will try that. I'm new to the forum and learning as I go! What a great resource for us old-timers keeping these classics on the water; I'm glad I found it!
Bud
August 04, 2013, 12:44:28 PM
« Reply #7 on: August 04, 2013, 12:44:28 PM »
Bud
I see that you have been "attaching" your photos - that's probably why you get thumbnails.  Take a look at the topic posted at the top of each forum that explains how to use our gallery - same technique applies to any photo hosting site.
August 09, 2013, 10:52:25 AM
budmanbud
« Reply #8 on: August 09, 2013, 10:52:25 AM »
Thanks, Rick. I'm going to take some more pictures of her this weekend and then I'll get them posted.
Cheers,
Bud Calloway
August 10, 2013, 08:31:54 PM
« Reply #9 on: August 10, 2013, 08:31:54 PM »
Good progress jmr.  I didn't see it mentioned, but did you check the foam in your stringers while you have everything apart?  Now is the time to replace it if it is soaking wet.
August 28, 2013, 03:37:54 PM
jmr1
« Reply #10 on: August 28, 2013, 03:37:54 PM »
The stringers look good and I'm not going to redo them just raise them up so I can raise my deck. The weather has sucked and kept me from doing the transom... I have finally started it and progress is slowly moving on.
The first 2 layers to start closing in the transom.
August 28, 2013, 06:10:58 PM
« Reply #11 on: August 28, 2013, 06:10:58 PM »
I strongly recommend you take some core samples of the foam in those stringers. Very very rarely is the foam not soaked and the wet foam sitting there for years can contribute to the stringers delaminating from the floor. You're doing a nice job on this hull so it doesnt make a lot of sense to take a short cut on a very critical detail that relates to the hull's integrity in the long run. Cut the tops off of the stringers, clean them out, add additional glass to the connection point and repour modern day closed cell foam and re-glass the tops. It's worth the trouble...
August 28, 2013, 06:27:30 PM
« Reply #12 on: August 28, 2013, 06:27:30 PM »
Quote from: "fitz73222"
^X2 if its worth doing its worth doing right!
August 29, 2013, 01:33:38 PM
jmr1
« Reply #13 on: August 29, 2013, 01:33:38 PM »
Sorry something happened to all my pictures so I reloaded them.
August 29, 2013, 11:42:17 PM
fishinonthebrain
« Reply #14 on: August 29, 2013, 11:42:17 PM »
Looking nice what are you going to use for coring the transom?
