Author Topic: steering problem  (Read 555 times)
July 01, 2013, 08:49:24 PM
Read 555 times
Gary911
steering problem
« on: July 01, 2013, 08:49:24 PM »
I have a 161 Tournament with a 2001 90hp Johnson on it. There is about 1&1/2 inch play in the steering . Not a real big problem but the boat does not stay straight when driving. I always have to turn the  wheel to stay straight and the steering is loose and sloppy. Does this mean the teleflex is worn and has to be replaced or is there an adjustment I can make to correct the problem. I checked the steering cable bolts at the engine, they are tight.
Gary
July 01, 2013, 09:41:49 PM
Re: steering problem
« Reply #1 on: July 01, 2013, 09:41:49 PM »
It could be the worm gear in the helm, it could be the cable end...it could be both.  Unfortunately, there are no adjustments to be made.  You have a 161 Tournament Cat (a rare breed around here) that is 12 years old.  May be time to start thinking about at least replacing the cable.
July 01, 2013, 09:51:04 PM
Gary911
« Reply #2 on: July 01, 2013, 09:51:04 PM »
Thank you for the info. Yes it is a rare find. Great little fishing boat.
July 01, 2013, 10:16:34 PM
gman 82 aquasport
« Reply #3 on: July 01, 2013, 10:16:34 PM »
If it's bad, have you thought of going hydraulic on a replacement?
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
July 02, 2013, 10:06:00 AM
Cyclops69
« Reply #4 on: July 02, 2013, 10:06:00 AM »
You may also want to adjust the angle of the trim zinc under the cavitation plate if it is torquing the wheel when you are planed out. It won't help with the slop in the wheel but it may take away the torque steer
1987 222 Osprey
