Chum
roll and tip method
Topic: roll and tip method (Read 395 times)
June 28, 2013, 01:50:52 PM
Read 395 times
love2fish
roll and tip method
June 28, 2013, 01:50:52 PM »
when rolling and tipping- do you do anything special with the brush? I found towards the end the brush would get "dried out" or saturated and would leave fine brush lines... on my next coat I was going to either get multiple brushes or see if putting it in something like acetone or 333 would help...
Thanks!
BTW- I'm using Brightsides..
Chris
\'74 22-2
Member #921
June 28, 2013, 02:06:28 PM
Re: roll and tip method
June 28, 2013, 02:06:28 PM »
Personally never had any luck with the roll and tip method, but patience isn't one of my virtues. Tried it when doing my bottom job, finally just went with a foam roller, but thats on the bottom...
June 28, 2013, 02:19:17 PM
Global Moderator
June 28, 2013, 02:19:17 PM »
Going on the assumption you may have missed this, here's a good read (found in our Resource forum).
viewtopic.php?p=17045#p17045
Here are the instructions (from above link) dealing with your question.
Clean the tipping brush with solvent every single time it is used. This keeps the brush from loading up and brush strokes in the paint unbelievably fine, hence they flow out and level as the paint sets.
June 28, 2013, 05:05:24 PM
love2fish
June 28, 2013, 05:05:24 PM »
perfect! thanks Bob- did a search but missed that one.
Chris
\'74 22-2
Member #921
July 02, 2013, 09:19:46 AM
gman 82 aquasport
July 02, 2013, 09:19:46 AM »
Capt. Bob is correct, if you keep the brush clean after every area of use you will get a much cleaner finish.I learned it the hard way first time around and then went and watched the video on shipshape TV..and it worked better..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
July 02, 2013, 09:49:30 AM
love2fish
July 02, 2013, 09:49:30 AM »
same here,,, first side and even 1/2 way up the 2nd side turned out great,,, but towards the bow onthe 2nd side, i could really notice some brush lines. took advantage of all this rain the past few days and did some 220 and 320 wet sanding, surface is like glass now for the next (hopefully final) coat.
Chris
\'74 22-2
Member #921
July 02, 2013, 09:54:06 AM
Global Moderator
July 02, 2013, 09:54:06 AM »
Love it.
This is how the Resource forum is meant to function.
And giving credit where due, a tip-o-the hat to the original member for the post....
JJ aka John Jones.
Chum
roll and tip method
