Author Topic: Johnson system check problem?  (Read 484 times)
June 19, 2013, 06:06:44 PM
Read 484 times
Mike453
  • NorthEast
« on: June 19, 2013, 06:06:44 PM »
Hi guys and gals, has anyone had this problem. I have a Johnson 115vxsss equipped with a system check gauge, I'm getting a NO OIL light with a constant horn. The book calls for a intermittent horn. After checking oil, motor and condition of plugs ( for heat) all looked ok, boat made it back ok . My question is, is there a test that will tell me if the oil pump is bad or i have some other problem, shop manual is unclear  on pump test. Thank You . Mike
2000 aquasport 200 osprey with 115 johnson
June 19, 2013, 06:27:25 PM
Re: Johnson system check problem?
« Reply #1 on: June 19, 2013, 06:27:25 PM »
Does the Johnson have a small oil reservoir on the engine? I have a Johnson but the PO disconnected the VRO so I'm not sure if they took the tank off too.  I have one on my Yammy and it'll send the alarm if it gets low too. It is what signals the main reservoir to pump oil over (a mechanic explained it that way).
June 19, 2013, 06:39:01 PM
« Reply #2 on: June 19, 2013, 06:39:01 PM »
No small tank under the cowl like a Merc.  But the main oil tank does have a level alarm.  Do you have a owners manual?
June 19, 2013, 06:51:09 PM
Mike453
  • NorthEast
« Reply #3 on: June 19, 2013, 06:51:09 PM »
There is no tank on the motor the tank on the deck has a level gauge connected to the system check and when the oil gets low you get an alarm and the Low oil light, I'm getting a No oil lamp.
June 19, 2013, 08:41:26 PM
« Reply #4 on: June 19, 2013, 08:41:26 PM »
I would check/replace the filter that resides within the oil tank itself.
June 19, 2013, 09:36:37 PM
« Reply #5 on: June 19, 2013, 09:36:37 PM »
Read this, it has been around a while but holds some truth about VRO systems
http://continuouswave.com/whaler/reference/VRO.html
June 19, 2013, 11:07:29 PM
Mike453
  • NorthEast
« Reply #6 on: June 19, 2013, 11:07:29 PM »
Thanks guys, ill check it out :salut:
