And that would be Andy Munao at SIM Yamaha in Washington Island WI. If you ever order parts from him (I do), you'll be dealing with his wonderful wife Lisa...
Hi guys,As the subject say Recently bought 2 F115 from 2002 Run them on the hose run goodTest run them on the water and run good wot 5800 at least one tach I could readThe other one was so sunburned could not read themAfter taking possession of the motors did some running around on low rpm because of ruff weatherChecking oil level and found milky oilDid some research and a cold engine running could cause this Pulled the thermostat Found stuck open will look tomorrow for a new onealso bought new tacho meters and changed them out found that the one I could not read before is not coming on!when I change the new meters it will come on so there is something wrong in the wiringIs there some one who has a wiring schematic that will be a great help to try to find my problemAlso installed a new fuel management meter from Yamaha and is also not coming onThe schematic that supplied is very limited hope fully there is a better one on CAAny help is much appreciatedThanksMartin
Quote from: "xo4001"Hi guys,As the subject say Recently bought 2 F115 from 2002 Run them on the hose run goodTest run them on the water and run good wot 5800 at least one tach I could readThe other one was so sunburned could not read themAfter taking possession of the motors did some running around on low rpm because of ruff weatherChecking oil level and found milky oilDid some research and a cold engine running could cause this Pulled the thermostat Found stuck open will look tomorrow for a new onealso bought new tacho meters and changed them out found that the one I could not read before is not coming on!when I change the new meters it will come on so there is something wrong in the wiringIs there some one who has a wiring schematic that will be a great help to try to find my problemAlso installed a new fuel management meter from Yamaha and is also not coming onThe schematic that supplied is very limited hope fully there is a better one on CAAny help is much appreciatedThanksMartinHi Martin,I would start by making sure you check the easy stuff. The drain plug for the oil pan has a washer on it. Make sure its there.If it was, then I would drop the lower unit and check up in the exhaust passage for corrosion. If you see much corrosion there, I would probably remove the powerhead and check the area underneath it for corrosion. You will know for sure once the powerhead is removed if that's the problem.I assume it runs well otherwise?Andy
Yamaha DOES have known corrosion issues and has made recent changes to their coatings.
